Snowferno Posted August 6, 2012 Share Posted August 6, 2012 I'm going to look at an 05 LGT LTD in a couple days, it has 74,700 miles. I'm wondering what is going to need to be replaced at the 75k milestone? That way I can either have them do the work before I buy the car or I can have them adjust the price accordingly. It's a 5EAT by the way Link to comment Share on other sites More sharing options...
Max Capacity Posted August 6, 2012 Share Posted August 6, 2012 Basically it's visual checking. Most major service is at 30,000 miles intervales. Look in the owners manual that should be with car, its all there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Pete1122 Posted August 6, 2012 Share Posted August 6, 2012 I did suspension at 75k, new struts and Whiteline bushings to replace the worn out OEM stuff. Link to comment Share on other sites More sharing options...
Snowferno Posted August 6, 2012 Author Share Posted August 6, 2012 When is the timing belt recommended on the LGT? I did mine around 75k on my DSM Link to comment Share on other sites More sharing options...
Max Capacity Posted August 6, 2012 Share Posted August 6, 2012 105,000 miles. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
