birchwood Posted August 5, 2012 Share Posted August 5, 2012 As a previous legacy GT owner, I am posting this question for a close friend. He has an 04 LGt with the 2.5 sohc motor, which needs to be replaced. He recently sourced a 2.5 sohc n/a motor from an 06, and is curious to know if the motor will work with no major issues. And help would be greatly appreciated. Thanks friends. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted August 6, 2012 Share Posted August 6, 2012 As a previous legacy GT owner, I am posting this question for a close friend. He has an 04 LGt with the 2.5 sohc motor, which needs to be replaced. He recently sourced a 2.5 sohc n/a motor from an 06, and is curious to know if the motor will work with no major issues. And help would be greatly appreciated. Thanks friends. Yes but make sure to use the ECU for the 06 EJ253 if you intend to swap the entire engine over and not just the short block Link to comment Share on other sites More sharing options...
