SubaruScully Posted July 22, 2012 Share Posted July 22, 2012 Ive had a small coolant leak ever since I bought my 90 legacy. Just today I got worse. I found that the leak is coming from the water pump. Planning on doing the water pump and timing belt. Im sure somebody has done this job before. Any thing to look out for? Any thing that I should replace whole I have the engine apart? Let me know. Link to comment Share on other sites More sharing options...
USLiberty Posted July 22, 2012 Share Posted July 22, 2012 How many miles? A timing belt kit with idler bearings, water pump, thermostat, oil pump, cam seals,front main seal and all the water/oil rubber hoses would basically rebuild the front of the motor . That could cost close to 5-600$ though. I did it with my jdm ej20g and it got much quieter and smoother. Should be good for 120,000 miles after that. Link to comment Share on other sites More sharing options...
SubaruScully Posted July 22, 2012 Author Share Posted July 22, 2012 There's 105 thousand miles on the car. Link to comment Share on other sites More sharing options...
USLiberty Posted July 23, 2012 Share Posted July 23, 2012 you could get away with another 40,000 on the oil pump but if you got the money its worth tge piece of mind. The timing belt kit should come with idler bearings. if not, buy new ones. All your rubber hoses should need replacing because of age alone.not sure if there's a hose kit, I just went to autozone and walked in back and found prebent hoses I could cut and make work. If you need some timing belt installation instructions, id be happy to take pics from my haynes repair manual. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted July 23, 2012 Share Posted July 23, 2012 RockAuto sells a timing kit with idlers, the belt and the water pump for $150, I believe. Link to comment Share on other sites More sharing options...
SubaruScully Posted July 23, 2012 Author Share Posted July 23, 2012 USliberty if you could take pics of the manual that would be great! Link to comment Share on other sites More sharing options...
