xkazik Posted July 21, 2012 Share Posted July 21, 2012 Hello everyone, after doing my oil change and getting gas at sunoco 93 octane, unless the guy at the pump messed up , I re flashed my cobb stage 1 93 octane map over again and now, RPMS drop to 500 when revving up in neutral. So now im not sure which one caused this to happen . I have a 5spd lgt 09 with 32,000 miles, has anyone on here have this happen before , please help !! Link to comment Share on other sites More sharing options...
Leviman Posted July 21, 2012 Share Posted July 21, 2012 Because you reflashed. Idle is always a bit shaky after a reflash. Link to comment Share on other sites More sharing options...
dryvby Posted July 21, 2012 Share Posted July 21, 2012 Ditto. ECU is re-learning idle. Link to comment Share on other sites More sharing options...
xkazik Posted July 21, 2012 Author Share Posted July 21, 2012 the car has never done this before after reflashing , plus its not going away after i drove for a while . anymore with more ideas ? Link to comment Share on other sites More sharing options...
Justin case Posted July 21, 2012 Share Posted July 21, 2012 My car has always seemed to do that. It did it before i got an accessport and still does it stage1. However whenever i cleared codes or when i reflashed it the first time i would have to crank it 3-4 times before it started and even after that it would die sometimes when coming to a stop. It stopped after a few good drives. Link to comment Share on other sites More sharing options...
iNVAR Posted July 22, 2012 Share Posted July 22, 2012 be patient, it'll stop. why did you reflash? as far as cranking, you're supposed to wait 5 seconds after turning the key to the on position before you actually start it because the ecu is rebooting. Link to comment Share on other sites More sharing options...
