madd0g37 Posted July 19, 2012 Share Posted July 19, 2012 Hi i have s jdm 97 legacy gt tt and it refuses to start. now go into alittle history here oh and a noobish i can do stuff if i can find what i am looking for or see a picture of it or a tutorial to follow it step by step. back in januray it started overheating so i wanted to find out why so i took the intercooler off had a look at the water piping under there big hole. so i then decided to check the water pump piping and noticed the water was leaking quite well from there also. so i decided that i best thing to do would be to replace with second hand piping replace water pump etc. so i did all this had to remove the top plenium off the top of the engine (to replace every piece of the piping on the outside of the engine).broke the bloody plastic air piping on the back replaced that with second hand part also. so all that done tryed starting it up. nothing. checked the belt e.g taking it off and resetting it just to make sure it was right. still nothing. and i checked all cables and fuses none blown. i tryed starting the car again. this time the starter motor seems to sound slower then before. when i try turning it over again it is slower and sounds like a grinding noise from the flywheel area but i am not sure. so i bought some software and cable from http://www.evoscan.com/ and have a look. got quite a few error codes. I cleared the error codes out and tryed again this is what i am getting. 11 crankshaft sensor 12 starter signal 21 engine coolant sensor 22 knock sensor 38 torque control signal #1 and #2 38 torque control permission signal 39 traction control system. been trying to find everything i can on these problem but with no luck. stop trying to fix it after awhile cus it is winter here in New Zealand now. started up again. any help would be great. Link to comment Share on other sites More sharing options...
madd0g37 Posted July 19, 2012 Author Share Posted July 19, 2012 also i just noticed when trying to turn it over i get 1 pop (and the pop is every now and again not every cycle) which i can hear goes out the back of the car not the front. and if i press heavily on the accel while trying to turn it over i can hear a faint clicking sound. Link to comment Share on other sites More sharing options...
subikid90 Posted July 19, 2012 Share Posted July 19, 2012 Did you make sure all of the sensors are plugged back in? -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
madd0g37 Posted July 19, 2012 Author Share Posted July 19, 2012 yes i have Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 19, 2012 I Donated Share Posted July 19, 2012 So what happens when you try and start it? Does it turn over and just not fire up? Does it do absolutly nothing. Does it sound like its spinning free? etc -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
madd0g37 Posted July 19, 2012 Author Share Posted July 19, 2012 it refuses to fire up i get a pop in one of the cyclinders. yes it sounds like it is spinning freely. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 19, 2012 I Donated Share Posted July 19, 2012 One of the turbos could have failed sucking a bunch of metal debris into the engine causing internal damage. You need to do a compression check -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
madd0g37 Posted July 19, 2012 Author Share Posted July 19, 2012 i don't have a compression tester the turbos were fine before i did this both spinning freely. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 19, 2012 I Donated Share Posted July 19, 2012 Get a compression tester. You need to do a compression test. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
madd0g37 Posted July 19, 2012 Author Share Posted July 19, 2012 ok and if the compression is fine, i get the feeling it's not but lets say it's not what would you say to do next? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 19, 2012 I Donated Share Posted July 19, 2012 Lets cross that bridge when/if we get there. From what you have explained to me, its a compression related issue. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
madd0g37 Posted July 19, 2012 Author Share Posted July 19, 2012 thanks. quick question what to do if its a fail? lol Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 19, 2012 I Donated Share Posted July 19, 2012 tear down the engine and find the internal problem. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
madd0g37 Posted July 19, 2012 Author Share Posted July 19, 2012 omg that sounds like hard work.i am a noob i think that abit out of my depth Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 19, 2012 I Donated Share Posted July 19, 2012 Maybe you should take it to a mechanic then. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
madd0g37 Posted July 19, 2012 Author Share Posted July 19, 2012 i wish i could afford that but i can't so i think i better learn fast lol Link to comment Share on other sites More sharing options...
