michiganSOOB Posted July 12, 2012 Share Posted July 12, 2012 my brighton needs new struts and springs and im looking for a reasonably priced solution. I'm not looking to lower my car i either want oem ride height or a slight lift. I have found several strut options so i'm good there but i cannot find coil springs for the life of me so if you guys could please help me find some oem or outback springs that are not priced to the sky it would be great Thanks, Brody Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 12, 2012 I Donated Share Posted July 12, 2012 Why do you need new springs? Needing to replace the springs is almost never needed. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SomethingWittyAsAUsername Posted July 12, 2012 Share Posted July 12, 2012 Needing to replace the springs is almost never needed. Unless you drive a Taurus. "Hai. My name Ford and I can car good" Link to comment Share on other sites More sharing options...
Stasis Posted July 12, 2012 Share Posted July 12, 2012 "Hai. My name Ford and I can car good" Link to comment Share on other sites More sharing options...
harrumphicus Posted July 12, 2012 Share Posted July 12, 2012 Speaking of which, the only parts I ever had to replace on my Mazda said "FoMoCo" on them. Link to comment Share on other sites More sharing options...
gergeek Posted July 12, 2012 Share Posted July 12, 2012 In order for my car to have less body roll im upgrading to a stiffer spring rate. You could raise your car using outback springs, or just go to Rock Auto for a new set and get replacement struts there. For a used set check here: LegacyGT.com http://legacygt.com/forums/forumdisplay.php/member-classifieds-2004-and-older-103.html Nasioc http://forums.nasioc.com/forums/forumdisplay.php?f=150 SL-i.net http://sl-i.net/FORUM/viewforum.php?f=22&sid=8ea143a607d5e16d560f652f2a582847 RS25.com http://www.rs25.com/forums/f179-fs-suspension Ebay http://www.ebay.com/sch/Suspension-Steering-/33579/i.html Link to comment Share on other sites More sharing options...
WESTcoast Posted July 12, 2012 Share Posted July 12, 2012 for best of both worlds I would go with kyb agx struts meant for an outback and find some stock outback springs. The strut differences will give you the lift you want and the agx struts are 10% stiffer than oem so you get you stiffness there. Plus if you know that your struts haven't been changed in a good minute, than most likely this setup will be day and night in ride quality. Link to comment Share on other sites More sharing options...
gergeek Posted July 12, 2012 Share Posted July 12, 2012 i always find the good deals of the FS forums to late, might just go up into Canada and see what they have at the import shops up there. would be a nice vacation too. Link to comment Share on other sites More sharing options...
michiganSOOB Posted July 12, 2012 Author Share Posted July 12, 2012 Why do you need new springs? Needing to replace the springs is almost never needed. im looking for a stiffer ride with my replacement but thanks for the input Link to comment Share on other sites More sharing options...
michiganSOOB Posted July 12, 2012 Author Share Posted July 12, 2012 thanks for the help i will keep ya posted on what i decide Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 12, 2012 I Donated Share Posted July 12, 2012 If you're wanting to use Subaru parts instead of performance aftermarket parts, 02-07 WRX or 04 STI stuff will work great. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
michiganSOOB Posted July 13, 2012 Author Share Posted July 13, 2012 http://www.ebay.com/itm/KYB-4-GR2-STRUTS-SHOCKS-SUBARU-LEGACY-AWD-4WD-95-99-/310275281324?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1996%7CMake%3ASubaru%7CModel%3ALegacy%7CSubmodel%3ABrighton&hash=item483dd911ac&vxp=mtr#ht_500wt_1156 seem legit? Link to comment Share on other sites More sharing options...
Stang70Fastback Posted July 13, 2012 Share Posted July 13, 2012 Pretty sure you can find them cheaper on http://www.rockauto.com Link to comment Share on other sites More sharing options...
Baddog Posted July 13, 2012 Share Posted July 13, 2012 Speaking of which, the only parts I ever had to replace on my Mazda said "FoMoCo" on them. Too many Ford parts on Mazda. Owned a 99 Mazda 626. Lasted 80k with dealer maintenance. Motor was Ford. Hate them Link to comment Share on other sites More sharing options...
michiganSOOB Posted July 17, 2012 Author Share Posted July 17, 2012 Just ordered KYB gr-2's through ebay, should be here by the weekend, i will post install and thoughts when i get them Link to comment Share on other sites More sharing options...
gergeek Posted July 17, 2012 Share Posted July 17, 2012 So are you keeping the springs stock ?? Link to comment Share on other sites More sharing options...
michiganSOOB Posted July 17, 2012 Author Share Posted July 17, 2012 It would appear so, i decided i am happy with the current ride height and i'm just going to clean up my springs and see if i'm ok with the new setup.I have a feeling new struts will be enough to get the feel i want. Link to comment Share on other sites More sharing options...
subikid90 Posted July 18, 2012 Share Posted July 18, 2012 Too many Ford parts on Mazda. Owned a 99 Mazda 626. Lasted 80k with dealer maintenance. Motor was Ford. Hate them amen! -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
gergeek Posted July 18, 2012 Share Posted July 18, 2012 ok let me know what the ride is like, i might edge up going your way too. Hopefully the GR2s reduce body roll Link to comment Share on other sites More sharing options...
michiganSOOB Posted July 19, 2012 Author Share Posted July 19, 2012 yeah if they don't eliminate enough body roll i'm going towards sways Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 19, 2012 I Donated Share Posted July 19, 2012 If you want to reduce body roll, you need to start with swaybars. They have the biggest effect on body roll -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
michiganSOOB Posted July 19, 2012 Author Share Posted July 19, 2012 If you want to reduce body roll, you need to start with swaybars. They have the biggest effect on body roll im aware of this, but i absolutely needed struts and what i was trying to say is that if im still unhappy with the ride i will get sway bars to furthur lessen body roll Link to comment Share on other sites More sharing options...
michiganSOOB Posted July 21, 2012 Author Share Posted July 21, 2012 Fedex brought me a saturday morning surprise Link to comment Share on other sites More sharing options...
michiganSOOB Posted July 22, 2012 Author Share Posted July 22, 2012 tore into the car tonight, got 3 struts off,on the right rear we have a stripped bolt that is waiting for tomorrow, should finish then too with pics to follow Link to comment Share on other sites More sharing options...
gergeek Posted July 23, 2012 Share Posted July 23, 2012 Update? Hows the ride? Link to comment Share on other sites More sharing options...
