Sbui Posted July 7, 2012 Share Posted July 7, 2012 hi i'm new here need a lil help with some stuff. i have a 02 wrx with some mods just wanted to see what would fit on the 05 legacy gt both are wagons. thanks for the help.:) i will post some pics of the gt soon vf48 sti tmic 750 top feed injector 255 fuel pump cobb intake bc racing coilovers whiteline sway/strut whiteline end links subaru 4 pot/2 pot breaks Link to comment Share on other sites More sharing options...
prash4902 Posted July 7, 2012 Share Posted July 7, 2012 Except the fuel pump, none would fit the 05 LGT. If you went with PW type IC, you could use the VF48 turbo. Link to comment Share on other sites More sharing options...
wrx-auto-x Posted July 8, 2012 Share Posted July 8, 2012 it was my understanding that the sti top mount would fit a legacy gt Link to comment Share on other sites More sharing options...
Sbui Posted July 8, 2012 Author Share Posted July 8, 2012 Thanks Link to comment Share on other sites More sharing options...
blongo804 Posted July 8, 2012 Share Posted July 8, 2012 it was my understanding that the sti top mount would fit a legacy gt Not unless STI intake manifold/throttle body are used (among a couple other things I think). Link to comment Share on other sites More sharing options...
dr_sharp Posted July 8, 2012 Share Posted July 8, 2012 The injectors would work on newer legacies with top feed (07+), but '05 used side feed. The VF48 will bolt up if you use the sti topmount or use an FMIC kit but as others have mentioned you will need the intake manifold from an STI to use the STi top mount. The pump should fit although you may have to modify the assembly to fit. Highly unlikely that any of the suspesion pieces would fit. lol Link to comment Share on other sites More sharing options...
scoobyscoodle Posted July 8, 2012 Share Posted July 8, 2012 ^+1 to what dr.sharp said. I bet you could use the WL end links. Also, just fyi, the subaru 4pot/2pot brakes are actually inferior to the oem legacygt brakes. The only oem subaru brakes that are an upgrade would be the sti brembos. Link to comment Share on other sites More sharing options...
blongo804 Posted July 8, 2012 Share Posted July 8, 2012 Also, just fyi, the subaru 4pot/2pot brakes are actually inferior to the oem legacygt brakes. The only oem subaru brakes that are an upgrade would be the sti brembos. Really? How so? Not doubting you at all just never came across this info and it's pretty sweet to know since I've always been jealous of those 4pot/2pot's. Link to comment Share on other sites More sharing options...
Sbui Posted July 8, 2012 Author Share Posted July 8, 2012 wowww guy thanks for all the info and for the bc if i change the top hat would that work? Link to comment Share on other sites More sharing options...
Sbui Posted July 8, 2012 Author Share Posted July 8, 2012 Not unless STI intake manifold/throttle body are used (among a couple other things I think). ok so i would have to buy the sti intake manifold/throttle body to put in the vf48 and the sti tmic? Link to comment Share on other sites More sharing options...
scoobyscoodle Posted July 8, 2012 Share Posted July 8, 2012 Really? How so? Not doubting you at all just never came across this info and it's pretty sweet to know since I've always been jealous of those 4pot/2pot's. Well, the 4pot/2pot is a fixed caliper, which is nice but won't really be that noticeable; but the big factor is pad surface area. Yes, the 4pot/2pot subaru calipers have more pistons than the legacygt brakes, but smaller pads. Smaller pads = quicker increase in temp = more fade. Your stopping distances are only going to shrink with better tires, so all the Brembos even do is just give you much more fade resistance. Aside from the Brembos, the legacygt oem brakes have the largest pads among subaru brakes. wowww guy thanks for all the info and for the bc if i change the top hat would that work? I doubt it. They will probably not bolt to the spindle either. ok so i would have to buy the sti intake manifold/throttle body to put in the vf48 and the sti tmic? Yes. You can also run the VF48 by using a Process West tmic for the legacy, or going with a fmic. Link to comment Share on other sites More sharing options...
dr_sharp Posted July 8, 2012 Share Posted July 8, 2012 Does process west sell a special silicon tube to make that work? On the hot side you'd need sti fitment and on the cold side you'd need LGT fitment. Thats pretty cool if so. lol Link to comment Share on other sites More sharing options...
scoobyscoodle Posted July 8, 2012 Share Posted July 8, 2012 Yes, they make a hose specifically for sti style turbos on the 08wrx/lgt. Rallisportdirect has them. Link to comment Share on other sites More sharing options...
Cyclozene Posted July 8, 2012 Share Posted July 8, 2012 Like others said you would need an sti manifold or fmic to use that turbo. Or! You can fab up your own tmic to work with the lgt plastic manifold. —Pirated Tapatalk app Link to comment Share on other sites More sharing options...
Sbui Posted July 8, 2012 Author Share Posted July 8, 2012 now would i need tgvs for the manifold? Link to comment Share on other sites More sharing options...
scoobyscoodle Posted July 8, 2012 Share Posted July 8, 2012 Not for the vf48. Link to comment Share on other sites More sharing options...
Sbui Posted July 8, 2012 Author Share Posted July 8, 2012 Ok thanks ordering manifold and thottle body now Link to comment Share on other sites More sharing options...
Cyclozene Posted July 9, 2012 Share Posted July 9, 2012 Your going to have fun with the build. Ive done the sti swap look for my write up. Its probably the best out there. Im not just saying that because I wrote it. You will need to dremel the holes on the manifold to fit the tgvs tho —Pirated Tapatalk app Link to comment Share on other sites More sharing options...
Cyclozene Posted July 9, 2012 Share Posted July 9, 2012 Dont order a new throttle body. You dont need it. The stock tb on your LGT works just fine —Pirated Tapatalk app Link to comment Share on other sites More sharing options...
Sbui Posted July 9, 2012 Author Share Posted July 9, 2012 ok cool will i was getting a good deal for it and he give me the sti tgvs i guess those would be a upgrade? Link to comment Share on other sites More sharing options...
Cyclozene Posted July 9, 2012 Share Posted July 9, 2012 Not really because you'll have to dremel them as well. Think about it. The bolts go thru the tgvs to the heads. Honestly keep the stock ones and stock tb. Save your money. Unless they are deleted. But save your money. Keep the lgt tgv and tb —Pirated Tapatalk app Link to comment Share on other sites More sharing options...
Sbui Posted July 9, 2012 Author Share Posted July 9, 2012 ok thanks for all the help!!! Link to comment Share on other sites More sharing options...
Cyclozene Posted July 9, 2012 Share Posted July 9, 2012 Not a problem just save money and be sure to keep us updated. You're going to have fun with the swap :trollface: —Pirated Tapatalk app Link to comment Share on other sites More sharing options...
Sbui Posted July 9, 2012 Author Share Posted July 9, 2012 Will do!!!! Link to comment Share on other sites More sharing options...
