taylormac1993 Posted July 5, 2012 Share Posted July 5, 2012 I'm replacing my head gaskets and shortly after taking the timing components off, I noticed a 12/14 Point ~15mm nut/bolt that I don't have the right socket for. I don't want to go buy the wrong socket and return it for a different size 4 or 5 times, so I need to know what size this bolt is. I don't know exactly what it does and I don't know exactly where it is, but it's on the timing belt side of the engine behind the rear timing belt covers. Does anyone know what size it is? Thanks in advance! Engine: EJ25D Car: 1998 Legacy Outback Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 5, 2012 I Donated Share Posted July 5, 2012 its a 14mm 12pt socket. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
JJay03 Posted July 6, 2012 Share Posted July 6, 2012 Why do you need to remove this bolt? The only 12pt bolt I had to remove was the head bolts. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 6, 2012 I Donated Share Posted July 6, 2012 I think you're talking about the bolts to split the block in half. You don't need to take that out. Only the head bolts...they are the same 12pt style...but are inside the heads. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
