SpecBamf41 Posted June 24, 2012 Share Posted June 24, 2012 You think a guy could unplug his iac and just use the screw on the Tb to adjust the idle speed? I would test this but my car wont run at the moment. Could someone try this for me? When I try and start my car with this new standalone I may try it with out the iac. And if it wont work at all there is no sense in trying it. Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 25, 2012 I Donated Share Posted June 25, 2012 You need IAC -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
jamesm113 Posted June 25, 2012 Share Posted June 25, 2012 When you turn on your accessories (radio, blower, AC, defroster, etc, etc.) the load on the motor is increased. The IAC adjusts the air entering the motor to compensate for that and allows for a smooth idle. So yes, you need it. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 25, 2012 I Donated Share Posted June 25, 2012 Unless you hire a mexican midget to live under your hood with a screwdriver to adjust your idle on the fly -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted June 25, 2012 Author Share Posted June 25, 2012 yeabut im not going to have ac/radio/blower defrost/.... im asking if the motor would start thefirst time. i can always add the fuction to the ms to control or iac. its just a 3 wire pwm iac right? BNR18g on 93oct Link to comment Share on other sites More sharing options...
joelwatts Posted June 25, 2012 Share Posted June 25, 2012 You need it. Car won't idle without it. Every time you were off the throttle the car would die as soon as the Rpms were low enough. It also opens up at wot so you would loose that as well. I'm a native of South Carolina. I am a dying breed. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted June 25, 2012 Author Share Posted June 25, 2012 i know it wont idle without it. thats why you crack the throttle body open a bit with the set screw. its like you didnt read anything.. and how would you know it opens at wot, im not even using the stock ecu. BNR18g on 93oct Link to comment Share on other sites More sharing options...
joelwatts Posted June 25, 2012 Share Posted June 25, 2012 Chill homie. I know your not using the Ecu. I assumed that you would like it to be open during wot but if not then that's fine. Also, the iac doesn't just open and stay in that spot. It constantly adjust its position to maintain ideal idle speed. So just cracking the throttle at idle won't allow for that adjustment so idle will be erratic at best. But it's up to you. Experiment and see what happens. If You don't want my advice, I'll shut up. I'm a native of South Carolina. I am a dying breed. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 25, 2012 I Donated Share Posted June 25, 2012 Go ahead and take shortcuts. I'll be waiting to laugh and say I told you so when your car isn't running -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted June 26, 2012 Author Share Posted June 26, 2012 well, sounds like no one has tied what im doing so how can you guys really know. ill try it and if not im just gonna have to use 2 outputs from the ms. BNR18g on 93oct Link to comment Share on other sites More sharing options...
dspl1236 Posted June 26, 2012 Share Posted June 26, 2012 i know quite a few guys who do not run a isv or iac on standalone. should be fine....just not perfect. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted June 26, 2012 Author Share Posted June 26, 2012 Ok sweet. Ill go for it. I don't need a perfect idle anyway Though someone tip me off on checking if some of the other components will work with boost when all their life they have seen vacuum. Things like the fuel pressure regulator and and Pcb valve. Also that charcoal canister thing. Can I just rig this up to the air line going back to the tank so when I fill at least I'm still pushing the vapors though a filter. And it has a one way valve so that would make vaccum in the tank which is bad or good. Or should I get rid of that valve Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted August 15, 2012 Author Share Posted August 15, 2012 Just had to come back and rub in face that the car runs fine with out an iacv. Just a little rough when trying to drive while cold. Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 15, 2012 I Donated Share Posted August 15, 2012 car runs fine with out an iacv. a little rough when trying to drive while cold. You just contradicted yourself. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted August 15, 2012 Author Share Posted August 15, 2012 While cold. Not because of the idle. It purrs at idle Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
joelwatts Posted August 15, 2012 Share Posted August 15, 2012 Congratulations. You win a who cares award. I'm a native of South Carolina. I am a dying breed. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted August 15, 2012 Author Share Posted August 15, 2012 What's the tracking number. Cant wait for my first award. Sent from my Galaxy Tab using TapaTalk 2 BNR18g on 93oct Link to comment Share on other sites More sharing options...
