suboogru Posted June 23, 2012 Share Posted June 23, 2012 I want to do the washer mod but my bolts are RUSTY and am assuming they will break off at the head. Does it matter what bolt it is replaced with, or just as long as it is long enough and fits inside the bolt hole. (Sorry Im probably the least mechanical person on this forum) Link to comment Share on other sites More sharing options...
angeltalin Posted June 23, 2012 Share Posted June 23, 2012 PB blaster? StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
No DRFT Posted June 23, 2012 Share Posted June 23, 2012 Yeah get bolts/nut from auto part store. Pb blaster works well too. I have no control over drippie. Link to comment Share on other sites More sharing options...
suboogru Posted June 23, 2012 Author Share Posted June 23, 2012 What's a pub blaster? Sounds delicious Link to comment Share on other sites More sharing options...
No DRFT Posted June 23, 2012 Share Posted June 23, 2012 Down a can and let me know how it taste. I have no control over drippie. Link to comment Share on other sites More sharing options...
suboogru Posted June 23, 2012 Author Share Posted June 23, 2012 Ha ha. For real though is it like liquid wrench or wd40 but stronger? If so will advance auto or a similar place carry it Link to comment Share on other sites More sharing options...
No DRFT Posted June 23, 2012 Share Posted June 23, 2012 Yes, it's a rust penetrant I have no control over drippie. Link to comment Share on other sites More sharing options...
suboogru Posted June 23, 2012 Author Share Posted June 23, 2012 OK I'll have to try it. Thanks a lot for the help Link to comment Share on other sites More sharing options...
Max Capacity Posted June 24, 2012 Share Posted June 24, 2012 Just buy any metric or sae bolt and nuts and bolt the thing back together. The flanges don't care what bolts you use. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
