SomethingWittyAsAUsername Posted June 22, 2012 Share Posted June 22, 2012 I get noise from one of my front wheels when I stop. Here's the thing though. It only happens when A) The brakes are cool, like when I first start off and B) When I slowly stop from around 15mph or less. The sound is hard to explain. Imagine what it would sound like if the pads and rotors were made of rock rather than steel. Otherwise, braking is normal. Very little shakes when stopping, no noises, and no decreased brake performance. What could this possibly be? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 22, 2012 I Donated Share Posted June 22, 2012 Could be lots of things. Most likely its poor quality brake pads. You could also try lubing the brakes. Take a look at my guide in the DIY thread at the top of the forum. The front brake guide shows all the spots to lube. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
gergeek Posted June 22, 2012 Share Posted June 22, 2012 What brok said. You could just try cleaning the rotors themselves.. and check the pads themselves, maybe need to be replaced..you might be hearing the metal clips that rub when the pads need to be change. Link to comment Share on other sites More sharing options...
