Moderators BarManBean Posted June 14, 2012 Moderators Share Posted June 14, 2012 I'm ordering a bushing replacement kit for kartboy endlinks since one of the little rubber pieces is torn. I'm confused because the kartboy website says the kit they have is not compatible for wagons. The previous own of the setup i have had it installed on a wagon and seems to have used the normal bushings...confused. Kartboy is telling me that they have a "crush tube" bushing for wagons, but I'd rather not order two of those (one for each side) if it's not needed and I can just order one of the new rubber sets. Anyone using crush tube bushings with their KB endlinks...never heard of this issue before. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
mr.hicksta Posted June 14, 2012 Share Posted June 14, 2012 Best bet would probably be to email or call Kartboy to get the skinny. But if Cutler wasn't using them I'd imagine you'll be fine. Just my .02... Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 14, 2012 Author Moderators Share Posted June 14, 2012 I am emailing them, talking with a guy named Tom. Problem is that I'm getting a bit of a run around and things like "i have it but it's not on the website"...also, like you said, if cutler wasn't using them they're probably fine... "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
mr.hicksta Posted June 14, 2012 Share Posted June 14, 2012 Tom = Kartboy owner I know their website leaves a bit to be desired too. I suppose it comes down to how worried you are about something going wrong if you don't have them. If I were you I would replace all the bushings, but that's just me. I say that because I recall some of the bushings looking pretty rough and you don't want any of them tearing. Link to comment Share on other sites More sharing options...
SGT Daddy Posted June 14, 2012 Share Posted June 14, 2012 I am emailing them, talking with a guy named Tom. Problem is that I'm getting a bit of a run around and things like "i have it but it's not on the website"...also, like you said, if cutler wasn't using them they're probably fine... I have the vendor information on where I got my endlinks they are kart boy. I dont know if they are"wagon" ones but they work very well. It is posted on a different forum under suspension/brakes. or I could be nice and find it and post it here for you. Link to comment Share on other sites More sharing options...
SGT Daddy Posted June 14, 2012 Share Posted June 14, 2012 Myles Williams Motorsports Marketing Director Racecomp Engineering LLC. and GTWORX.com 512 SHAW CT UNIT 104 SEVERN, Maryland 21144 LANDLINE 410-846-5407 Mobile 443-370-9000 www.racecompengineering.com www.gtworx.com Here you go, I am in a helping mood this morning. Link to comment Share on other sites More sharing options...
mr.hicksta Posted June 14, 2012 Share Posted June 14, 2012 Lucky you BarManBean, he's in a helping mood this morning! :lol: Link to comment Share on other sites More sharing options...
SGT Daddy Posted June 14, 2012 Share Posted June 14, 2012 I try. Some times any ways. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 14, 2012 Author Moderators Share Posted June 14, 2012 Will give 'em a call, thanks. I don't think I'll be replacing all of the bushings (would be $120 for all of them, seems a bit excessive at the moment!) If they do tear, it won't be the end of the world to get under there and put some new ones in. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
jasejase Posted June 14, 2012 Share Posted June 14, 2012 fwit, i installed the same kartboy endlinks on my gt and my buddy's outback... same kartboy part numbers. They fit in both instances (with the silver spacers) onto the fsb. Link to comment Share on other sites More sharing options...
mr.hicksta Posted June 14, 2012 Share Posted June 14, 2012 BMB - Just sent you a PM. I would deal with Kartboy direct if I were you, but wait until I get that info I mentioned in the PM. Link to comment Share on other sites More sharing options...
jamal Posted June 14, 2012 Share Posted June 14, 2012 Wagon endlinks are not for the 05-09 Legacy regardless of whether it is a wagon. The wagon refers to the WRX wagon from 02-07. All 90-04 Legacies and 93-01 Imprezas also use "wagon" endlinks. The difference is in the mount on the front control arms. The "wagon" arms are like this: http://jamalb.net/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=1014&g2_serialNumber=2 And you can see that the lower hole is smaller: http://jamalb.net/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=1010&g2_serialNumber=2 "Sedan" arms, like are on all 05-09 Legacies, mount the endlink differently, in single shear, and use the same size bolt top and bottom: http://hellafunctional.com/wp-content/uploads/2012/06/Front-endlinks.jpg So in conclusion, even if you have an LGT wagon, you need "sedan" front endlinks. Link to comment Share on other sites More sharing options...
goneskiian Posted June 14, 2012 Share Posted June 14, 2012 Thanks for the clarification jamal! I was worried there for a second as I have some of these waiting to go on and I'd never heard of the wagons needing a different endlink. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 15, 2012 Author Moderators Share Posted June 15, 2012 So in conclusion, even if you have an LGT wagon, you need "sedan" front endlinks. That's EXACTLY what I was looking for, thanks jamal! "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
