Max Capacity Posted June 20, 2012 Share Posted June 20, 2012 http://legacygt.com/forums/showthread.php/got-some-new-stuff-engine-r-r-184106.html Look in my thread, there are pictures there you may find useful. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
trepetti Posted June 20, 2012 Author Share Posted June 20, 2012 http://legacygt.com/forums/showthread.php/got-some-new-stuff-engine-r-r-184106.html Look in my thread, there are pictures there you may find useful. I will be looking it over carefully in the next few. I am beginning to get that dread that I do not have the parts I need. So far I have: Oil pipe (both the short Turbo feed and the big one) Turbo up pipe gasket Turbo down pipe gasket Center to front exhaust gasket Compressor to intercooloer o-ring all new banjo bolts and washers (pulled the screen form the bolt) intake manifold o-rings TGV gaskets New turbo oil return and clamps Any glaring omissions? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 20, 2012 Share Posted June 20, 2012 You should not need the orange o-rings. Your not going to take that apart, Only pull the (I think 4) long bolts that hold the TVG to the heads. Do you have anti-seize compouind for putting things back together ? All nut's and bolts get anti-seize, even lug nuts. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
trepetti Posted June 20, 2012 Author Share Posted June 20, 2012 I got the o-rings just in case......Did not pick up the anti-seize yes but it is on the list...... Thanks Link to comment Share on other sites More sharing options...
