seeking Posted June 12, 2012 Share Posted June 12, 2012 Hello, Can someone please point me to a supplier of parts for a JDM subaru. My vehicle AT light flashes 16 time at start up, and a self diagnostic produce code 24- IAC Valve. From my research and your helpful posts it seem I will be seeking the following parts: Clutch Pack Duty C IAV valve. Is the transmission Internal components of the TZ102YBDBA changeable with either of these transmission. - TZ102YBAAA - TZ102YBABA - TZ102YBCBA What code/ type transmission do the US Dual turbo use. Vehicle specs: 1997 Subaru Legacy: 2.0 JDM (Dual Turbo) Heavy Industries LTD E-BDS VIN# BDS-029458 Aplied Model BDSC48P Option Code: AHC Trim Code: 710 Engine Type: EJ20 Color Code: 51E Transmission Type: TZ102YBDBA One more try for a fix before I send her to the parts yard. Note: I am searching from the Cayman Islands Regards: Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 12, 2012 I Donated Share Posted June 12, 2012 You can likely clean the IAC with carburetor cleaner. And the US has never had a twin turbo Subaru. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
seeking Posted August 29, 2012 Author Share Posted August 29, 2012 After a lot of searching I found the following parts source for a JDM Subaru. Very good service and fast shipment.. I am putting it up just in case someone else had problems sourcing parts for A JDM as I did.. Speed sensor and Duty-C (valve assembly) Part # below.. Gave him my JDM Vin and presto.. Chisato Yamamoto Suitparts.com 3-13 Tokiwa-cho, Kuwana, Mie 511-0062 Japan tel: 0594-22-9139 fax: 0594-23-9315 Speed Sensor / 85082-AC002 Valve Assy / 31942-AA090 ( Duty C Sylenoid ) Link to comment Share on other sites More sharing options...
seeking Posted November 1, 2012 Author Share Posted November 1, 2012 Following up: Installed the Duty-C and speed sensor, good fix no codes and no blinking lights. found a leak at the turbo inlet/induction pipe, will have to replace the inlet which will require removal of the manifold. Also found the part# and Diagram on a Russian site I was able to cross reference with Yamamoto who agree it is a match for the 97 legacy.. I will try to put up the picture for anyone who may be seeking same.. I cannot find the russian site again but I continue to search. Will post the link if I find it again. The parts diagram also shows how things go back together also. If someone know the address please post.. As for removing the manifold i have my labels and patience in stock. Link to comment Share on other sites More sharing options...
seeking Posted November 3, 2012 Author Share Posted November 3, 2012 Site address follows: http://www.megazip.ru/ru/auto/subaru/view/362/2719/36552/337465 This new guy don't know how to do a direct link on this forum yet.. But trying.. Hope this helps someone. Link to comment Share on other sites More sharing options...
seeking Posted November 15, 2012 Author Share Posted November 15, 2012 Another helpful find if you need to point to an item location on the legacy engine. The knock sensor for example is in the area of grid (I-4) hope this helps someone. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 16, 2012 Share Posted November 16, 2012 the knock is more like F-3, fail BNR18g on 93oct Link to comment Share on other sites More sharing options...
Stasis Posted November 16, 2012 Share Posted November 16, 2012 That's odd, must be the ej20H, layout is slightly different from R. Link to comment Share on other sites More sharing options...
seeking Posted November 26, 2012 Author Share Posted November 26, 2012 Been digging into the Legacy, Just replaced the Turbo inlet pipe. Removing the manifold was a bear, but very satisfying getting every thing back together. I having been getting any responses, so I was trying to be helpful when I visit. Picture is almost identical to my RS; the assembly attached to the intercooler at Grid G-3 is located on the bottom of my intercooler, area C-1. other than that it looks identical to my RS.. Stang70Fastback: Thanks for the correction ; I will have to be more exacting next time.. I agree the teacher would not have given me a pass either. The grid works though. I had to remove a hose from the reservoir located at grid A-4, all of the fluid leaked out, and I am trying to determine what type fluid to replace. Looks like motor oil, but I don't know for sure. My repair manual don't even show it. Anyone knows what type fluid is used in there. It seems to be a recovery tank for oil traveling to the radiator for cooling. Help!! Link to comment Share on other sites More sharing options...
Stasis Posted November 26, 2012 Share Posted November 26, 2012 A-4 is the coolant resevoir... Unless you meant to say something other than A4 Link to comment Share on other sites More sharing options...
seeking Posted November 26, 2012 Author Share Posted November 26, 2012 Stasis: Thanks. Yes the reservoir falls on grid A between 4&5. Had a closer, look the hose I disconnected may have been an oil line feeding oil to the reservoir inner core for cooling. The residue in the tank is green, so antifreeze seem to match.. Will add some coolant and try for a start up this afternoon.. Better safe than sorry.. Thanks again.. Link to comment Share on other sites More sharing options...
seeking Posted November 26, 2012 Author Share Posted November 26, 2012 Did a start up this afternoon, engine started with a little rough idle until the computer relearned and accepted what I did. Still no light or fault codes.. Youtube and all the helpful folks are the best. Keep on posting and thanks to all who helped this newbie. Next project 911 wiring and fit-out, I have all the gear for a complete re-do and now retired, the time hope.. Finally; I used a spray nozel from a bottle to take out all the fluid from my power-steering resiviour works well.. The bottle I got from a shipment of POR-15/metal ready, even have a clear tube and you can see when the ATF color change as you flush out the old for new.. Next time.. Link to comment Share on other sites More sharing options...
