Lanaue Posted June 6, 2012 Share Posted June 6, 2012 I have an 07 GT with 58k on it and it's starting to overheat under lite loads. I'n hoping it's not the HG. i've been losing coolant. It look like it's coming from the front some where but I can't get it to leak when at idle. It seams as if the fmi is going dry first. But i see coolant on the top of the fans. Link to comment Share on other sites More sharing options...
underground000 Posted June 6, 2012 Share Posted June 6, 2012 maybe radiator? its plastic so check around the plastic areas 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
Max Capacity Posted June 6, 2012 Share Posted June 6, 2012 If the fans have coolant on them it must be leaking at the top of the radiator under the showd area. Check the top hose for a pin leak ??? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
