Ibenz Posted June 5, 2012 Share Posted June 5, 2012 I was a 99 brighton wagon. when I go around tight corners, say turning from one side street to another going 30km/h or faster the rear tires chirp. should i change the rear diff fluid? I know it has not been done in a long time, if ever. Thanks Link to comment Share on other sites More sharing options...
MasAyinde Posted June 5, 2012 Share Posted June 5, 2012 It might just be your alignment. Link to comment Share on other sites More sharing options...
johnegg Posted June 5, 2012 Share Posted June 5, 2012 it sounds like torque bind. auto or manual trans? usually caused by a bad part in the ''transfer clutch'' in the rear extension housing on the trans. auto and manual repairs are different only because the trans are different. but it could be caused by an odd size tire, or improper inflation. check your tires, they should be all the same brand, size, tread, inflation, and wear. Link to comment Share on other sites More sharing options...
Ibenz Posted June 5, 2012 Author Share Posted June 5, 2012 All the tires are the same, all new a year ago with lots of tread still. It is a 5spd, and it does need a clutch soon (slipping). The other day when I was doing my rear breaks (which wont stop squeaking now, drums) I had only one side of the car jacked and buddy I was doing it with spun the tire around a few times, would this do this? Link to comment Share on other sites More sharing options...
johnegg Posted June 5, 2012 Share Posted June 5, 2012 the manual trans has a viscous coupling in the rear extension of the trans. this is like a limited slip differential, at least the limited slip part. when the from wheels (trans out put shaft) is spinning faster than the rear wheels, (output shaft) the viscous coupling ''grabs / grips'' tighter and reduces / eliminates the slip (speed difference). when this viscous coupling fails, it tends to ''grab'' all the time creating a ''locked'' 4wd set up. this is just like a 4wd truck on dry pavement with ''locked'' front hubs. this causes torque bind, or the stuff you are feeling in tight slow turns. the fix is replacing the viscous unit which can be done with out removing the trans. or replacing the trans. the trick is finding one you know is good. you can find a lot of parts at www.car-part.com but i doubt they will list this part. you may have to call and talk to the yard to see if they have what you need. or place an ad here in the ''wanted'' section of the classifieds. Link to comment Share on other sites More sharing options...
Ibenz Posted June 6, 2012 Author Share Posted June 6, 2012 ok thanks for the info. I have guy close to where I live that has a yard full of subarus, ill give him a call. Will my service manual have enough info about removing and replacing this? Link to comment Share on other sites More sharing options...
johnegg Posted June 6, 2012 Share Posted June 6, 2012 you can use a viscous unit out of any manual trans 90 - 04. this does not mean you can swap in any manual trans 90 - 04. the outbacks and GTs have different final drive ratio. so study up or ask before you buy a complete trans for a swap. Link to comment Share on other sites More sharing options...
Ibenz Posted June 7, 2012 Author Share Posted June 7, 2012 thanks for all the info. Is this something I should have fixed soon or is it fine if I wait a month or two and have it fixed when I replace my clutch? Link to comment Share on other sites More sharing options...
johnegg Posted June 9, 2012 Share Posted June 9, 2012 this should work in your car. http://legacygt.com/forums/showthread.php/viscous-coupling-1999-otbk-5spd-sale-184354.html?t=184354&highlight=viscous Link to comment Share on other sites More sharing options...
SpecBamf41 Posted June 10, 2012 Share Posted June 10, 2012 my car has the same problem. the car will somtimes bind so bad that it stops in its tracks while turning into a park space. does anyone know what actually is causeing it to go bad? i just put fluild in. not subaru fluid but snythetic 75-90 BNR18g on 93oct Link to comment Share on other sites More sharing options...
johnegg Posted June 10, 2012 Share Posted June 10, 2012 my car has the same problem. the car will somtimes bind so bad that it stops in its tracks while turning into a park space. does anyone know what actually is causeing it to go bad? i just put fluild in. not subaru fluid but snythetic 75-90 year model miles and trans please????? Link to comment Share on other sites More sharing options...
Ibenz Posted July 7, 2012 Author Share Posted July 7, 2012 Turns out it was a wheel bearing Link to comment Share on other sites More sharing options...
