rdp2n Posted June 3, 2012 Share Posted June 3, 2012 When I start this 1995 legacy there is a (quite loud) screeching sound that goes away after a second or 2. I think it's coming from the steering pump area. I recently removed the steering pump and replaced a couple of seals. The steering fluid level now seems stable and there is no sign of steering fluid on the top of the engine -- so I think that problem is addressed -- but I have this screech on startup instead. I tightened the steering pump belt and it looks reasonable taught. Is it likely too tight -- or do I need to tighten it further? Thanks, Rob Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 3, 2012 I Donated Share Posted June 3, 2012 It can be too tight as well it can need to be replaced. A bearing could be going out in one of the pulleys too -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
rdp2n Posted June 11, 2012 Author Share Posted June 11, 2012 OK -- I tightened the belt down pretty much as far as the adjustment would go -- now it starts without the screech. Don't quite understand why it needed that -- maybe the belt is a bit stretched and will need to be replaced soon. Thanks for your response broknindarkagain. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 11, 2012 I Donated Share Posted June 11, 2012 OK -- I tightened the belt down pretty much as far as the adjustment would go -- now it starts without the screech. Don't quite understand why it needed that -- maybe the belt is a bit stretched and will need to be replaced soon. Thanks for your response broknindarkagain. Anytime -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
