lingling1337 Posted May 24, 2012 Share Posted May 24, 2012 Hey all just noticed a little squeak coming from the clutch pedal today. No unusual conditions to speak of that would have caused it (no launching etc.), and no symptoms other than the noise. The sound is a definite squeak/creak while I press the clutch in, and a creak or a whirr while I let the clutch out- I noticed the whirr noise a couple times right after I shifted. I have never heard of a problem like this, anyone have any guesses? I can go look at my car again if anyone has questions. I'll also be taking a vid next time I drive. Link to comment Share on other sites More sharing options...
lingling1337 Posted May 25, 2012 Author Share Posted May 25, 2012 Just drove another few miles and noticed the transmission/drivetrain seems noiser, especially in 4th gear. Could this have something to do with the new tire I put on? It should be well within Subaru's spec of 2/32 treadwear tolerance Link to comment Share on other sites More sharing options...
06specb366 Posted May 25, 2012 Share Posted May 25, 2012 i have an 06 specb. doing thesame thing. hopefully someone knows whats up. would really like to get rid of it!lol! good luck! Link to comment Share on other sites More sharing options...
lowwill Posted May 25, 2012 Share Posted May 25, 2012 I notice a weird sound after changing the clutch out. It started after about 1k miles. Squeezy type of noise. Everything is new except the flywheel. Wondering on if it needs a bleeding. Good luck Link to comment Share on other sites More sharing options...
Max Capacity Posted May 25, 2012 Share Posted May 25, 2012 With the engine at idle, tranny in neutral, push in the clutch pedal and release it as fast as possible, side step the pedal and let the pedal slam to the top. Tranny whining can sometimes be a rear wheel bearing going. My tranny is much quieter after I replaced the left rear wheel bearing. lowwill I wouldn't bleed the clutch for your problem. There should be no reason to do that, unless you lost the fluid. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lingling1337 Posted May 25, 2012 Author Share Posted May 25, 2012 With the engine at idle, tranny in neutral, push in the clutch pedal and release it as fast as possible, side step the pedal and let the pedal slam to the top. Tranny whining can sometimes be a rear wheel bearing going. My tranny is much quieter after I replaced the left rear wheel bearing. lowwill I wouldn't bleed the clutch for your problem. There should be no reason to do that, unless you lost the fluid. What should I be looking for in the test you described first? Wheel bearing was actually a thought of mine. Is there a way to check it visually? EDIT: And as I've been driving, I noticed that the squeal is prominent as I get higher in first gear. From then it's inaudible/only audible when I shift. Link to comment Share on other sites More sharing options...
