SevenNukes1 Posted May 24, 2012 Share Posted May 24, 2012 Hey guys, Just replaced the belt, and all pulleys. Everything was fine except I noticed a small difference when putting in the new idler gear. The old one stuck out about 1/16" more than the new one. This means the belt doesn't line up perfectly with the gear like it does with all the other elements. Picture is attached. Everything is back together, car runs fine, but wanted to post a picture and get your opinions on whether or not I should worry about it. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 24, 2012 Share Posted May 24, 2012 I'd put a washer behind that to move it out. But you say the car is running now. I think you'll be fine. That is there just to route the belt, it's not like it's driving the belt. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
sbw Posted May 24, 2012 Share Posted May 24, 2012 IMO, you will be fine. Link to comment Share on other sites More sharing options...
SevenNukes1 Posted May 24, 2012 Author Share Posted May 24, 2012 Thanks guys, I'm just a little paranoid. I know when the timing belt goes the engine can destroy itself. Don't want to be dealing with that repair bill anytime in the near future. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 25, 2012 Share Posted May 25, 2012 I am assuming you changed your tensioner as well. Link to comment Share on other sites More sharing options...
xero287 Posted May 25, 2012 Share Posted May 25, 2012 ^Trying to instill that one last bit of fear in the OP eh? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 25, 2012 Share Posted May 25, 2012 ^Trying to instill that one last bit of fear in the OP eh? juuust prevention..You may have seen that thread but this happened to me . Link to comment Share on other sites More sharing options...
