jaygt1 Posted May 22, 2012 Share Posted May 22, 2012 Lately my car has been overheating... at least I think so. The gauge doesn't read anything abnormal, but after 30 mins of continuous driving, I notice a faint smoke coming from the hood. It smells as if something is burning. The car has about 75,xxx mi and the coolant level is full. I am completely lost. I was thinking maybe a thermostat or the "bubble" problem, but any insight would be great. Thanks Link to comment Share on other sites More sharing options...
Wonder_Boy Posted May 22, 2012 Share Posted May 22, 2012 Would the faint smoke happen to occur on the passenger side of the engine? Link to comment Share on other sites More sharing options...
jaygt1 Posted May 22, 2012 Author Share Posted May 22, 2012 Nope, about 10,000 miles ago I had the turbo replaced Link to comment Share on other sites More sharing options...
Wonder_Boy Posted May 22, 2012 Share Posted May 22, 2012 There goes my busted CV boot theory. Is the entire engine bay smoking? Link to comment Share on other sites More sharing options...
legacyshawn Posted May 22, 2012 Share Posted May 22, 2012 Oil from a recent oil change burning? Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted May 22, 2012 Mega Users Share Posted May 22, 2012 leaking valve cover gasket dripping on exhaust manifold "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
scoobyscoodle Posted May 22, 2012 Share Posted May 22, 2012 Have you been monitoring the oil level? Is it stable? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 22, 2012 Share Posted May 22, 2012 leaking valve cover gasket dripping on exhaust manifold I'm guessing this is the correct guess. Can someone close to this guy, recommend a good shop for him to take it too so they can tell him whats worng. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
robitrice Posted May 22, 2012 Share Posted May 22, 2012 color of the smoke? white general is coolant and bluish is oil. how do your coolant hoses look? Are your fans turning on? Link to comment Share on other sites More sharing options...
m sprank Posted May 22, 2012 Share Posted May 22, 2012 I'm guessing this is the correct guess. Can someone close to this guy, recommend a good shop for him to take it too so they can tell him whats wrong. Or a hose clamp/hose leaking from the turbo install. Probably re-used hoses and cheap OEM spring clamps. Link to comment Share on other sites More sharing options...
silen7guardian Posted May 22, 2012 Share Posted May 22, 2012 On my '05 Outback XT with 106k miles, oil is leaking from my timing belt cover (presumably from cam shaft and/or crank shaft seals). It drips onto the exhaust heat shield, which produces symptoms similar to what you're describing. I plan to fix mine this summer. If oil is leaking from your timing belt cover, you will not only need to replace all seals that are leaking, but you will need to replace your timing belt (oil degrades rubber). On a related side-note: Since you have a 5EAT, you may want to consider a light-weight crank pulley while you're in there (if you do your own repair work). I plan to add the light-weight pulley to mine and go catless at the same time. My spool time should be greatly decreased. I'm kind of excited, since it will be my first power mod besides an open-source tune. Link to comment Share on other sites More sharing options...
m sprank Posted May 22, 2012 Share Posted May 22, 2012 Welcome to the forum. A LWCP is a decent upgrade for the money on a 5EAT. Link to comment Share on other sites More sharing options...
