joee1212 Posted May 20, 2012 Share Posted May 20, 2012 i have a 05 gt 2-5 tubro and i am trying to line up all the timing marks but the left side gears i get them set then move to putting on the belt but can not keep in one place they go a round like there spring loaded is there a way to keep in one place thanks joe:icon_conf Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted May 20, 2012 Mega Users Share Posted May 20, 2012 Do you mean the driver's side? Those will be loaded if you've lined up the crank at TDC. Use an allen wrench to line up the bottom and a strap wrench to line up the top at the same time and use some vice grips to hold the two cams together once lined up and keep them from moving. The vice grips have to be tight, but if you go too tight, it might crack them. Link to comment Share on other sites More sharing options...
joee1212 Posted May 20, 2012 Author Share Posted May 20, 2012 thanks i will try that Link to comment Share on other sites More sharing options...
