1-3-2-4 Posted May 20, 2012 Share Posted May 20, 2012 This is going to sound like a stupid question but I never tried shifting at the transmission before and it looks and feels different from the shifter, I must be in reverse when moving the shifter rod to the left in the transfer case section you can see which opposing forces labels as the neutral switch moves and I'm unable to move the rod again until I rotate it again to unlock it from the position.. in the effort to not make this sound more confusing I can't figure out how to find all 5 years.. If I just pull it straight out and back in, it seems like it has 3 positions. Turning both drive shafts you can tell it must be in a higher gear because the effort to turn it becomes much greater. Link to comment Share on other sites More sharing options...
