jasejase Posted May 15, 2012 Share Posted May 15, 2012 in addition to the poppits, do you use those four grille clips? (the 'red circles' above) Link to comment Share on other sites More sharing options...
bmx045 Posted May 15, 2012 Share Posted May 15, 2012 yup just the red circle ones, grille doesn't move. Link to comment Share on other sites More sharing options...
jasejase Posted May 15, 2012 Share Posted May 15, 2012 Nice. good to know. Link to comment Share on other sites More sharing options...
I Donated Too luchadorjose Posted May 15, 2012 I Donated Too Share Posted May 15, 2012 three of the 4 upper grill clips on my car are broken and don't lock, they just sit in place. That plus 2 pop-its hold it fine, never had an issue Link to comment Share on other sites More sharing options...
jasejase Posted May 15, 2012 Share Posted May 15, 2012 yeah, two of my grill clips are toast... Link to comment Share on other sites More sharing options...
cmbezln Posted May 15, 2012 Author Share Posted May 15, 2012 Assuming the gt's are the same as the n/a's (which they should be)... you do not have to remove the bumper in the 09's. My buddy with an 08 lgt insists that he DOES have to remove the bumper, but in my 09, i did not have to. A matter of fact, i can take my grill out in about 2 minutes. Open the hood. There are some screws or plastic uphostery screw clips at the top of the grill.. maybe 2... maybe 4. cant remember. Then there are 4 (i think) 'clips.' You push in the little tabs on the clips, and that (along with the removed screws) sets the entire top of the assembly free... .The bottom rests in slots of some sort iirc. Just kinda pull up at an angle. Wiggle a bit, and it should come free. Unless mine came broken from the factory! If this makes no sense, i blame the cold meds. I can take a pic or something if really needed. I actually was able to finally get the grill off and this isn't entirely true there are six screws, including two that are very deep connecting the grill to the bumper. You probably originally took them off and never put them back in (which a lot of people had said they did). I had to bend back the grill far in order to get a very short phillips head screwdriver down there to remove the remaining screws and then was able to remove it retarded design if you ask me. Link to comment Share on other sites More sharing options...
cmbezln Posted May 15, 2012 Author Share Posted May 15, 2012 apparently, grillcraft needs to be informed of this as well: http://www.grillcraft.com/installs/install_detail.aspx?install_id=265 Link to comment Share on other sites More sharing options...
jasejase Posted May 15, 2012 Share Posted May 15, 2012 I actually was able to finally get the grill off and this isn't entirely true there are six screws, including two that are very deep connecting the grill to the bumper. You probably originally took them off and never put them back in (which a lot of people had said they did). I had to bend back the grill far in order to get a very short phillips head screwdriver down there to remove the remaining screws and then was able to remove it retarded design if you ask me. Yeah, if you scroll past my post, you can see a boat load of other posts stating that there were screws in there. Apparently the prior owner for whatever reason, removed them for me! Looking at the grill again, with the proper tools, you shouldnt have to drop the bumper cover. Link to comment Share on other sites More sharing options...
SpecBGuy Posted May 15, 2012 Share Posted May 15, 2012 i thought it was just me on the top grille clip breaking. i have one broken and rest are fine. i dont use them with my new grille since it has no attachment holes for it anyways. Link to comment Share on other sites More sharing options...
