raff e30 Posted May 14, 2012 Share Posted May 14, 2012 hi 97 2.0 ej20 twin turbo legacy i checked the compression on all cylinders theyr all 9 bar or 130 psi all plugs are perfect and the oil is clean. however theres exhaust fumes in the coolant are my headgaskets gone?? the engine idles perfect and revs perfect Link to comment Share on other sites More sharing options...
jamesm113 Posted May 14, 2012 Share Posted May 14, 2012 Yes, you'll need to replace them, how else would exhaust get in the coolant? Link to comment Share on other sites More sharing options...
Kennyfvholla Posted May 15, 2012 Share Posted May 15, 2012 Agreed. The gaskets fail internally. The exhaust leaks through the chamber/bore seal and super heats the coolant and that's why you overheat. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 15, 2012 I Donated Share Posted May 15, 2012 Head gaskets on your engine are a crappy design and start leaking after awhile. The EJ25D has the same kind of failure. Buy a set of 1.6 custom made steel head gaskets from Cometic. They will last you a life time. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
