blicraft Posted May 14, 2012 Share Posted May 14, 2012 Hello, Just starting out on my stage 1 tune. Mods so far K&N panel filter, Snorkel delete which I'll be adding back as soon as I find it, and catless up pipe. I have a LC-1 wideband that will be installed later on. I've attached my learning view logs let me know what you think. Link to comment Share on other sites More sharing options...
rtbrjason Posted May 14, 2012 Share Posted May 14, 2012 The pulled timing isn't ideal but then neither are the load columns so you can't really tell where the knock is occurring at the higher load, though it is mostly correcting itself. The change in filter is going to lean you out a bit so if you're self tuning keep fuel conservative ( low 10s) until you can scale the intake and verify with wideband. Link to comment Share on other sites More sharing options...
bmx045 Posted May 14, 2012 Share Posted May 14, 2012 here's a tip, save yourself some aggrivation and put the stock intake back to the way it came from the factory, go to autozone and get an stp filter, the fact that you have a k&n and snorkel delete does absolutely nothing for performance and is only hurting your fuel trims. revert back to stock and re-evaluate learning view, that way you can eliminate a possible culprit of knock (due to a lean condition) Link to comment Share on other sites More sharing options...
blicraft Posted May 14, 2012 Author Share Posted May 14, 2012 Yeah I'm trying to find my snorkel otherwise I'll have to pick one up here used. I'll head down to the auto-parts store and pick up a new filter. Thanks for the advice. Link to comment Share on other sites More sharing options...
bmx045 Posted May 14, 2012 Share Posted May 14, 2012 if anything, put a stock filter back in. the placenta jug that hangs underneath it should be there, but if you can get that, block the open hole with tape on the underside. Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted May 14, 2012 Mega Users Share Posted May 14, 2012 placenta jug that hangs underneath... :lol: "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted May 15, 2012 Mega Users Share Posted May 15, 2012 You need the placenta jug. And you should definitely go back to the oem fetus filter. I bet that will clean up the knock on the LV. Link to comment Share on other sites More sharing options...
