captain337 Posted May 4, 2012 Share Posted May 4, 2012 I noticed yesterday that I could no longer roll the rear passenger window down (only up) from the driver's control. The rear passenger switch still operates the window as normal (up and down). Should I focus my attention on the driver's control switch or is there some sort of window control module that might be suspect? Link to comment Share on other sites More sharing options...
Heedz Posted May 6, 2012 Share Posted May 6, 2012 May be a sticky front module just grab a new one. Link to comment Share on other sites More sharing options...
2005outbackxt Posted May 6, 2012 Share Posted May 6, 2012 its either a problem with the drivers master switch or a wire broken in the door jam of the drivers door the master switch is a common problem with those cars and so is the wires breaking in the door jam Link to comment Share on other sites More sharing options...
