nKoan Posted July 13, 2005 Share Posted July 13, 2005 Perrin comes with a pre-fabbed bracket support brace that seems to work pretty good. The way it connects it though the subframe bolt/hole near the bracket and to the bracket itself on the lower of the two bolt holes for the bushing mount. A longer bolt with some washers is supplied w/ the Perrin kit. (like I said though, I don't have direct personally experience with anything but Perrin, so I don't know how it compares). Link to comment Share on other sites More sharing options...
eVoMotion Posted July 13, 2005 Share Posted July 13, 2005 Thanks - Perrin is local to me. I will check in with them. Link to comment Share on other sites More sharing options...
PDXTuning Posted July 13, 2005 Share Posted July 13, 2005 You can come by the shop and check it out on my car also. I have the LGT at the shop today so feel free to stop by, give me a call first to make sure I am not out running around though. Jarrad Link to comment Share on other sites More sharing options...
PDXTuning Posted July 13, 2005 Share Posted July 13, 2005 My sedan is perfectly quiet with it. I will ask Perrin if he made any chances from the early units. I have pictures of a broken bracket from a upgraded bar that was not reinforced. There must be some front to back forces, cause that is what broke this one clean off. Jarrad I had nothing but issues with the Perrin bracket - it didn't fit properly and the mounting hole needed to be opened up (same problem DM had). Knocking noise at all speeds....it went away when I removed the brackets. Besides - how much load does the factory mount get front to rear? The brackets are designed to reinforce in that direction, not side to side where it seems some bracing would be needed. Jon aka '03Indigo' had noise issues too. Note that we both have wagons. Link to comment Share on other sites More sharing options...
eVoMotion Posted July 13, 2005 Share Posted July 13, 2005 We are detailing our 97LGT tonight so we can take it down to Carr to trade it for a 05 OBXT. I definitely will come by soon. You can come by the shop and check it out on my car also. I have the LGT at the shop today so feel free to stop by, give me a call first to make sure I am not out running around though. Jarrad Link to comment Share on other sites More sharing options...
nKoan Posted July 13, 2005 Share Posted July 13, 2005 I haven't had problems with the Perrin brace either. It was hard to put in (and get lined up perfectly) but judicious use of a FordTool (aka, rubber mallet) got everything lined up. Once it was in, its fine. No noise whatsoever. After talking with Adam (I believe) at Perrin, he did say that there was an update to the RSB package, but I don't think it had anything to do with the brace. The bushing was updated, and a bushing spacer was no longer necessary. For what its worth, I have the new setup with the larger bushing that didn't need a spacer. Link to comment Share on other sites More sharing options...
CRAZY KEN Posted July 14, 2005 Share Posted July 14, 2005 Thanks to Grand Master Sifu Keefe (Xenonk) He has installed: Cusco's Front and Rear Strut Tower Bar Vacanza's Front and Rear Swaybar ...and on the 23rd of July he'll be installing: Cusco's Front and Rear Lower Arm Braces Cusco's Front and Rear Endlinks STi Pink Springs I'll be also swapping out my summer wheel/tire combo (Prodrive GC-06 18" British Black with Toyo T1-S 225/40 ZR18) with a stickier combo (Volk LE37K 17" with Toyo RA-1 235/45ZR17) after a couple of days of letting the springs settle I'll get a four wheel alignment with me in the drivers seat! Can't wait!!! Thanks again Grand Master Sifu Keefe (Xenonk), CRAZY KEN P.S. Saving up for these babys..then I will be done with my suspension! http://www.avoturboworld.com/avoshop/product_info.php?products_id=273&osCsid=6b5513fe9ef4c463ab3b1b05e68b921a Link to comment Share on other sites More sharing options...
PGT Posted July 14, 2005 Share Posted July 14, 2005 what did you do with the Prodrives??? <----secretly wishes for GC series love Link to comment Share on other sites More sharing options...
praedet Posted July 14, 2005 Share Posted July 14, 2005 (Prodrive GC-06 18" British Black with Toyo T1-S 225/40 ZR18)Were these the 18x7.5s? How much did the rims weigh? I am looking at these rims exactly for a SWP Wagon... Ted Link to comment Share on other sites More sharing options...
CRAZY KEN Posted July 14, 2005 Share Posted July 14, 2005 http://www.prodrive.com/pagefiles/GC06.jpg 18" x 7.5" (not for sale) 16-17 LBS....just trying out the stickier combo! CRAZY KEN Link to comment Share on other sites More sharing options...
KayGT Posted July 15, 2005 Share Posted July 15, 2005 where can i buy a jdm sway bar? Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted July 15, 2005 Share Posted July 15, 2005 where can i buy a jdm sway bar? AVO PM apexjapan. OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
03Indigo Posted July 15, 2005 Share Posted July 15, 2005 I had nothing but issues with the Perrin bracket - it didn't fit properly and the mounting hole needed to be opened up (same problem DM had). Knocking noise at all speeds....it went away when I removed the brackets. Besides - how much load does the factory mount get front to rear? The brackets are designed to reinforce in that direction, not side to side where it seems some bracing would be needed. Jon aka '03Indigo' had noise issues too. Note that we both have wagons. I do have the perrin bars, but my clunking is in the front, not the rear where the bracing is. Might not be a sway bar issues at al...that is still pending. My rear braces are solid. No issues what so ever. I also had no fitment issues when I installed the Perrin brackets/braces. http://www.rmcb5.com/albums/album73/IMG_0900.jpg http://www.rmcb5.com/albums/album73/IMG_0907.jpg Link to comment Share on other sites More sharing options...
