RoB3984LgT Posted April 28, 2012 Share Posted April 28, 2012 Ok so this all started about a month ago with some surging and some loss of power. After screwing around with it for a bit I cleaned my maf and did a top engine service... things cleared up for a bit( like 2 weeks). Now its back again so I did some logs and sent them down to my tuner at r/t tuning. He got back to me with some serious concern about my dynamic advance(dam) dropped to (.12) and showing some fine knock. Heres a copy of 2 of the data logs I took yesterday and sent to him. Please let mme know if you have any ideas??? NOTE: I use the same 93oct hess gas all the time from the same place.good run 1.csvgood run 2.csv Link to comment Share on other sites More sharing options...
authenticamd Posted April 28, 2012 Share Posted April 28, 2012 What stage are you? I see your wastgate duty cycle is 0 the entire time. If I had to guess, some line popped off. Hopefully someone with more knowledge will comment. It's pretty bad you're knocking even at 0.12 DAM. Link to comment Share on other sites More sharing options...
RoB3984LgT Posted April 28, 2012 Author Share Posted April 28, 2012 Im stage 2. I have no clue what up with that wastegate either?? Im guessing its because im not hitting target boost at 17lbs??? Im going to go check the lines now but im almost certain they are all good, I have check all that 1000 times. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted April 28, 2012 Mega Users Share Posted April 28, 2012 Once dynamic advance gets below a certain point, the wastegate will stay at 0. So you'll be limited to spring pressure. That's weird though, because you shouldn't be hitting 15psi with the WGDC at 0. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted April 28, 2012 Mega Users Share Posted April 28, 2012 And it's probably not a good idea to do any more pulls with it running the way it is. Link to comment Share on other sites More sharing options...
RoB3984LgT Posted April 28, 2012 Author Share Posted April 28, 2012 Yea Im thinking the same thing def no more hard pulls until I get this figured out. Im going to run some sunoco 100octane and see what kind of knock im getting then. Maybe its just a fuel quality issue??? Link to comment Share on other sites More sharing options...
RoB3984LgT Posted May 16, 2012 Author Share Posted May 16, 2012 UPDATE* Well ive had several ppl go over some more logs and no luck... The general idea from most everyone is that its not actually knocking! This is beyond frustrating at this point.. I changed the knock sensor to a new oem one, still picking up knock... Im starting to think its phantom knock as well? After probing around for possible couses im thinking it may be the engine cover tapping the perrin tmic, as it is a cut cover so that it will fit. There are bolts on the bottom half but not the top half of the cover so maybe its tapping. Anyways I took it off last night so well see what happens on the way into work. Phantom knock would explain this problem and its irratic behavior. It has no gradual drop in DAM it goes from a perfect 1.0 to 0.0 to .6 just jumping around. Other times its solid locked in a 1.0??? Anyone know of any sources for phanotm knock that they have dealt with?? Thanks for the help guys. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted May 16, 2012 Mega Users Share Posted May 16, 2012 I think someone else had a similar issue. I think the knock sensor is under the intercooler, so thats a possibility. Link to comment Share on other sites More sharing options...
Cincy05LGT Posted August 20, 2012 Share Posted August 20, 2012 Any resolution to this problem? Link to comment Share on other sites More sharing options...
fishbone Posted August 21, 2012 Share Posted August 21, 2012 Welcome to my world buddy. I've been "dealing" with a similar issue for what, 3 years now? Basically DAM will occasionally drop a step down from 1, there have been times on the same tune during the winter I have seen it at 0.6 and even 0.0 at steady throttle in 4th gear. Let me guess. You are driving the automatic in manual mode? Link to comment Share on other sites More sharing options...
