Theride Posted April 27, 2012 Share Posted April 27, 2012 Does anyone know the size of the TOP radiator support bolts? I was changing my rotors and read that you can use them to pop the rotors off. I tried and now they are shreded because it seems they were too big for the rotor holes. I had to use the bolts holding the ABDS/WHEEL SENSOR?..to the struts to get the rotors off. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 27, 2012 Share Posted April 27, 2012 8mmx1.25 Go to the auto parts store and ask the guy to show you where the packages of nuts and bolts are. You can buy a kit for about $8.00 Next time put anti-seize compound on the threads before you thread them into the rotors. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Theride Posted April 27, 2012 Author Share Posted April 27, 2012 Appreciated. I'm still puzzled as to why both bolts stripped and the ones connecting the ABS?...didn't strip. I got it rectified however. Thanks Link to comment Share on other sites More sharing options...
Theride Posted April 27, 2012 Author Share Posted April 27, 2012 . Link to comment Share on other sites More sharing options...
mwm5094 Posted April 29, 2012 Share Posted April 29, 2012 maybe someone used them too many times for rear brake removal? Link to comment Share on other sites More sharing options...
