joee1212 Posted April 21, 2012 Share Posted April 21, 2012 :confused:i have a 05 legacy gt 2.5 tubro that engin light on and the code reader said p0011 a camshaft position timing over advanced or system performance bank 1 can someone tell me what this is thanks joe Link to comment Share on other sites More sharing options...
bmx045 Posted April 21, 2012 Share Posted April 21, 2012 need a new avcs oil control valve or a banjo filter is clogged meaning oil delivery flow issues. Both can cause that code. If its the passenger side, and i cant remember if 11 is driver or passenger right now, check your turbo shaft play after you inspect the banjo filter. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 21, 2012 Share Posted April 21, 2012 What year car ? Also what he said... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
VermontGT Posted April 22, 2012 Share Posted April 22, 2012 :confused:i have a 05 legacy gt Link to comment Share on other sites More sharing options...
