apexjapan Posted April 20, 2012 Share Posted April 20, 2012 Just a fun little progression of recovering a muffler tip from long burnt plastic, using tools at hand. They've been sitting around for a while, so decided to have a go at it. All of this would be fairly easy if you had a big buffing wheel designed for this sort of thing. This is for all those people that don't. yeah, pretty ugly. http://www.avoturboworld.com/images/muffler/muffler_fix_001.jpg Heat gun set to Obliviate to soften it up a bit. It and a box knife blade for getting the major stuff off first. http://www.avoturboworld.com/images/muffler/muffler_fix_002.jpg After trying a variety of other chemical methods, it got down to doing it the hard way. http://www.avoturboworld.com/images/muffler/muffler_fix_003.jpg Now for the fun part... http://www.avoturboworld.com/images/muffler/muffler_fix_004.jpg A lot of polishing via what was on hand. Having all the proper equipment (big buffers) would help. Used a simple (small) dremel buffer with some buffing compound. http://www.avoturboworld.com/images/muffler/muffler_fix_005.jpg And then the final touch by hand. http://www.avoturboworld.com/images/muffler/muffler_fix_006.jpg Regards, Paul Hansen http://www.avoturboworld.com http://www.facebook.com/avoturboworld Link to comment Share on other sites More sharing options...
tdcmr2 Posted April 20, 2012 Share Posted April 20, 2012 Did you try gasoline? It should dissolve it Link to comment Share on other sites More sharing options...
apexjapan Posted April 20, 2012 Author Share Posted April 20, 2012 I did, it didn't. I think in most cases it will, this was a bit on the extreme recovery side. Regards, Paul Hansen Link to comment Share on other sites More sharing options...
Chameleon Posted April 24, 2012 Share Posted April 24, 2012 Great ... i have always wondered this but never tackled it. Thanks Link to comment Share on other sites More sharing options...
