sdale Posted April 11, 2012 Share Posted April 11, 2012 Transmission hard to get into gear initially but seems to get better after it warms up. This first started to happen a few months back and I just figured it was the slave so I replaced the slave and it worked perfect for two days. Now I am guessed that there is a leak in the master cylinder. So I replaced that now it worked perfect for two more days. At this point I am guessing I have a leak in the line but when I bled no air would come out. Now at the end of the day I leave my car in the street in gear start the car and engage 1st it is ok. If I start the car neutral it is very hard to get it into gear as I force it the car moves would that be a throw out bearing? After it warms you can feel it “snap in to gear” Any ides?????? Link to comment Share on other sites More sharing options...
sdale Posted April 13, 2012 Author Share Posted April 13, 2012 I forgot to to mention i put a spec stage 1 clutch about 10k ago Link to comment Share on other sites More sharing options...
ProjectSega Posted April 13, 2012 Share Posted April 13, 2012 I have the same problem. The strange part is it was getting into gear was perfectly fine til i took it into the dealership to check a problem. When I returned to pick up my car, it was difficult to get into gear. Dealership said they didn't do anything other than inspect the problem...... What kinda helped was I changed to the tranny fluid to Redline Lightweight shockproof and Motul: http://legacygt.com/forums/showthread.php/redline-lightweight-shock-proof-173978.html Still a little difficult to get into gear on cold start, but in goes in gear. Wonder what else could be the problem though... Link to comment Share on other sites More sharing options...
Max Capacity Posted April 13, 2012 Share Posted April 13, 2012 PM BAC5.2 he's the expert on manual tranny's ! 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
