rallispec Posted April 11, 2012 Share Posted April 11, 2012 I lost the upper bolt that hold the caliper in place on the front passenger side brake. No local dealership stocks that bolt, so I want to order it online somewhere. Any suggestions? It is part # 26387c on the attached diagram. It is an 8mm x 1.00 (fine pitch) 20mm long. (I think) I was able to get something close enough from the local ace hardware to keep me going, but I'd like to get a solid automotive grade piece in there. Any thoughts? Link to comment Share on other sites More sharing options...
CL21376 Posted April 11, 2012 Share Posted April 11, 2012 I lost the upper bolt that hold the caliper in place on the front passenger side brake. No local dealership stocks that bolt, so I want to order it online somewhere. Any suggestions? It is part # 26387c on the attached diagram. It is an 8mm x 1.00 (fine pitch) 20mm long. (I think) I was able to get something close enough from the local ace hardware to keep me going, but I'd like to get a solid automotive grade piece in there. Any thoughts? I managed to lose one of those also and just had the dealer order it. Cost a couple bucks but took 3 days to get in. In the meantime I got an automotive grade replacement from NAPA, put 2 nuts on it and cut it to size with my dremel. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 11, 2012 Share Posted April 11, 2012 McMaster-Carr may have what your looking for. Last year I went to the dealer because I just wanted to replace the same bolts on my 05. He showed me some corse thread bolt that was bigger. When I said I think mine are finner thread, the parts guy said this is what they always use. I turned and walked away. Here, all I see are 8x1.25 though http://www.mcmaster.com/#standard-cap-screws/=h26rwu The fronts are bigger then the rears. Just so you know. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
