LegacyDan Posted April 6, 2012 Share Posted April 6, 2012 Anyone know whats the max amount of boost the oem BOV can deal with without leaking? Running 22 psi on new engine currently with a GFB stealth FX BOV but getting tired of the ricer noise so will either set it to 100% recirc or switch back to OEM one. should it be ok at 22 psi? Link to comment Share on other sites More sharing options...
mr.hicksta Posted April 6, 2012 Share Posted April 6, 2012 I've read 20 psi is pushing it with the OEM BPV. You may want to consider checking out the Forge 100% recirc BPV. You can change out springs based on how much boost you're running. Link to comment Share on other sites More sharing options...
LegacyDan Posted April 6, 2012 Author Share Posted April 6, 2012 as far as i know the GFB one has an adjustment style to tighten or loosen the spring tension, just need to find the blanking screw to set it to 100% recirc if i want to use that Link to comment Share on other sites More sharing options...
mr.hicksta Posted April 6, 2012 Share Posted April 6, 2012 You're talking about the GFB Respons BPV I believe. I had that for a bit. While it's nice, even at 100% recirc you still get a little sound. The Forge is just a beefier OEM style BPV, which is very nice IMO. Check it out: http://www.rallysportdirect.com/Forge-FMDVWRX3B-Recirculation-Valve-Black Link to comment Share on other sites More sharing options...
jasejase Posted April 6, 2012 Share Posted April 6, 2012 your pushing the envelope at 22 psi. Many people have issues at 20 or so on... Some people start to develop issues at 18+. Depends on the age of the BOV, and a bit of luck from what i can gather! Everyone claims that full recirc is a safe approach... I went with a Full recirc Turbosmart Kompact. They are essentially a super heavy duty OEM.. About $150 Link to comment Share on other sites More sharing options...
12sechatch Posted April 6, 2012 Share Posted April 6, 2012 conventional wisdom says it can handle up to 20-22psi. Just run an aftermarket BPV if you dont want the 'ricer' noise. Link to comment Share on other sites More sharing options...
jasejase Posted April 6, 2012 Share Posted April 6, 2012 ^^ agreed Link to comment Share on other sites More sharing options...
bmx045 Posted April 6, 2012 Share Posted April 6, 2012 some oem bpv's start leaking as low as 18psi.... some do some dont. i went with a forge and never looked back Link to comment Share on other sites More sharing options...
LegacyDan Posted April 6, 2012 Author Share Posted April 6, 2012 so which be the best recirc valve to be looking at when running 20+ psi of boost? Forge has already gotten some good recommendations Link to comment Share on other sites More sharing options...
jasejase Posted April 6, 2012 Share Posted April 6, 2012 The forge ones have been around for a while, and ppl love them. The TurboSmart Kompact (as i said before) is the one that i have, and it works well. The piece is made very nicely, and is heavy as all hell. I dont think you can go wrong with either. My installer stocks and loves the TurboSmart one... The price was also nice at $150 new. Link to comment Share on other sites More sharing options...
mr.hicksta Posted April 6, 2012 Share Posted April 6, 2012 Forge because you can swap springs based on how much boost you're running. Yellow spring is good to 22 or 23psi and the other ones can hold more than that. Plus it's QUIET Link to comment Share on other sites More sharing options...
Nrw Posted April 6, 2012 Share Posted April 6, 2012 You can throw a forge at a wall and it will still work Link to comment Share on other sites More sharing options...
bmx045 Posted April 6, 2012 Share Posted April 6, 2012 its solid alu-minium Link to comment Share on other sites More sharing options...
LegacyDan Posted April 6, 2012 Author Share Posted April 6, 2012 You can throw a forge at a wall and it will still work speaking from experience? I had a look for the adapter to change my GFB from 50/50 to 100% recirc but no sign of it. So looks like ill need to get a new valve, ill check out the forge recirc ones and turbosmart Link to comment Share on other sites More sharing options...
jasejase Posted April 6, 2012 Share Posted April 6, 2012 i believe the TS one is also solid aluminum. Im sure they are similiar. Not too many people use the TurboSmarts on lgt's yet. Believe they started more so on the wrx's... Either way, still a 'newer' item in the bpv world. Dont think there's a wrong choice between the two (from what i have seen at least) Link to comment Share on other sites More sharing options...
frank_ster Posted April 6, 2012 Share Posted April 6, 2012 i boosted up to 25 psi with the stock one. keep in mind its not the bov that starts to fail at higher pressures its because pressure is not reaching the activation side of the bov. potentially the bov can handle 40 psi of boost. if the line going to it and the orafice in the intake is large enough. people always go to a stiffer spring as a bandaid. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
