new2theru Posted April 5, 2012 Share Posted April 5, 2012 I have a 2007 Legacy gt 5eat and have recently noticed a knocking sound. It sounds like an engine knock but the dtrange thing is I can only hear it from inside the car with the windows up and doors closed. I've raised the hood and cant hear anything but valve chatter and normal engine noise. The oil level is good and always changed at 3500 miles. Anyone else ever experience this or know of what it could be? Link to comment Share on other sites More sharing options...
Max Capacity Posted April 5, 2012 Share Posted April 5, 2012 turn off the blower for the fan in the heater. Do you hear this sound at idle ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
new2theru Posted April 5, 2012 Author Share Posted April 5, 2012 I hear the sound at idle and as i give it gas its gets faster with engine speed. I've turned off everything I can to try and hear it better. Sometimes it sounds like a deisel in the cabin but I cannot hear it from outside the car. Could it be a rod knock? Would'nt that be something I would hear under the hood though? Link to comment Share on other sites More sharing options...
bmx045 Posted April 6, 2012 Share Posted April 6, 2012 sounds like rod knock. take a video. youtube subaru rod knock and see if it sounds like that Link to comment Share on other sites More sharing options...
AZP Installs Posted April 7, 2012 Share Posted April 7, 2012 It could also have to do with something inside the trans as well especially if you hear it. Inside the cabin but not inside the engine bay. -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.2971 | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
new2theru Posted April 11, 2012 Author Share Posted April 11, 2012 Funny you say that it may be the trans I had a trans flush at the local Subaru dealership and they put the wrong fluid back in and I had to get it redine the next day but have had my concerns with it like if they really redid it with the correct fluid or not and if replacing all the fluid with the wrong kind could have done anything to it cause it did feel like it was slipping and not knowing what to do for a while after having it done but after about 500 miles that seemed to fade Link to comment Share on other sites More sharing options...
Max Capacity Posted April 13, 2012 Share Posted April 13, 2012 Funny you say that, it may be the trans. I had a trans flush at the local Subaru dealership and they put the wrong fluid back in. Then I had to get it redine the next day. but have had my concerns with it. like if they really redid it with the correct fluid or not. and if replacing all the fluid with the wrong kind could have done anything to it cause it. did feel like it was slipping and not knowing what to do for a while after having it done but after about 500 miles that seemed to fade Wow, I can't even fix all of that. Please read what you write before you post it. It will make it easier for those of us trying to help. You must have a automatic, contact ClimberD@HEXMODS for help, He's the expert. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
new2theru Posted April 18, 2012 Author Share Posted April 18, 2012 Wow, I can't even fix all of that. Please read what you write before you post it. It will make it easier for those of us trying to help. You must have a automatic, contact ClimberD@HEXMODS for help, He's the expert. Sorry about my lack of puncuation. But yes it is an automatic hense the 5eat in my very first post. Link to comment Share on other sites More sharing options...
new2theru Posted April 18, 2012 Author Share Posted April 18, 2012 I do appreciate the feedback from everyone and I think this forum is very helpful. I am however fairly new to the forum seen and as you have noticed my typing skills are near zero. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 18, 2012 Share Posted April 18, 2012 If you open the hood with the engine running. Where do you hear the noise ? From the middle of the engine block or to one or both sides ? Is it a heavy knock or a lighter sound ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SSpeed Posted April 18, 2012 Share Posted April 18, 2012 The rod knock I've seen is at its worst right around 3500rpm. Link to comment Share on other sites More sharing options...
bmx045 Posted April 18, 2012 Share Posted April 18, 2012 my rod knock was when the engine was fully warmed, in Drive, at a redlight. it would sound pretty bad. it would go away though when on the gas... Link to comment Share on other sites More sharing options...
