Drogos Posted April 4, 2012 Share Posted April 4, 2012 I finally want to get a decent, real deal air gauge. I am sick of using toys that kind of show you what your pressure is. I found this: Intercomp 4" analog Accutire digital I am always sceptical when I see digital gauges so I am leaning towards the first one but maybe anyone can recommend something different. thanks Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted April 4, 2012 Share Posted April 4, 2012 Longacre Racing gauges are a good investment. I have the magnum 4". Link to comment Share on other sites More sharing options...
Drogos Posted April 4, 2012 Author Share Posted April 4, 2012 Liquid filled ... what the hack??? Also do you guys recommend angled or ball fitting Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted April 4, 2012 Share Posted April 4, 2012 Ball, and liquid filling isn't necessary. Link to comment Share on other sites More sharing options...
jasejase Posted April 4, 2012 Share Posted April 4, 2012 i have a couple traditional ones (as in your first links design), but cant think of the manufacturer... I also do have a digital accutire, and it works really well. It's always spot on against my ol' fashioned ones. Just keep it out of the garage in the winter. Cold KILLS the battery in it quickly. Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted April 4, 2012 Share Posted April 4, 2012 I used to use the Accutire digital gauges, but after buying 3 $20 gauges that all broke one after another at some point for one reason or another, I decided to spend the $60-70 on a quality gauge that would last a lifetime (Longacre will also re-calibrate your gauge for you at any time). Link to comment Share on other sites More sharing options...
jasejase Posted April 4, 2012 Share Posted April 4, 2012 guess i've had good luck! Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted April 4, 2012 Share Posted April 4, 2012 guess i've had good luck! When they work correctly, they're very accurate. I used the same one for years before it finally broke, then the two that replaced them both had different issues. Link to comment Share on other sites More sharing options...
jasejase Posted April 4, 2012 Share Posted April 4, 2012 dont make 'em like they used to. Link to comment Share on other sites More sharing options...
dtmenace Posted April 4, 2012 Share Posted April 4, 2012 my preference is for this type, the rubber coating on the housing makes them significantly more durable & the pass-through allows you to measure while adding air to the tire: http://www.pashnit.com/pics/products/CyclePump/EZ-AIR_400.jpg Link to comment Share on other sites More sharing options...
scoobyscoodle Posted April 5, 2012 Share Posted April 5, 2012 +1 for Longacre. Link to comment Share on other sites More sharing options...
tito_b0y Posted April 5, 2012 Share Posted April 5, 2012 'Nother plug for Longacre. I've got the liquid-filled one and it's pretty accurate to my local ETD's gauge. 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
froggert Posted April 6, 2012 Share Posted April 6, 2012 i've been using an accugage for the last few years. $20 or so, has a bleeder valve, fits any wheel and reads consistently. Link to comment Share on other sites More sharing options...
dtmenace Posted April 6, 2012 Share Posted April 6, 2012 froggert??? where the hell did you come from? welcome back? Link to comment Share on other sites More sharing options...
