cypher0117 Posted April 2, 2012 Share Posted April 2, 2012 I have had my whiteline 20mm rsb installed with kartboy endlinks for 5 days and I am getting clunking/smacking of metal on metal. I have noticed that my rear lower lateral link (toe adjustment arm) is coming in contact with the swaybar. Paint is already warn through to metal. My car is lowered .8" in the rear with eibach pro kit. What would be the easiest way to fix this issue and has anyone had to deal with this before with the same/similar setup? Thanks! Link to comment Share on other sites More sharing options...
bmx045 Posted April 2, 2012 Share Posted April 2, 2012 same happens with rallitek rear bars. you need longer endlinks.... Link to comment Share on other sites More sharing options...
cypher0117 Posted April 3, 2012 Author Share Posted April 3, 2012 Has anyone tried grinding the top part of the toe arm off to make more clearance? I wonder if that would just cause the trailing arm to hit the bar instead... Link to comment Share on other sites More sharing options...
bmx045 Posted April 3, 2012 Share Posted April 3, 2012 i would not do that Link to comment Share on other sites More sharing options...
cypher0117 Posted April 3, 2012 Author Share Posted April 3, 2012 I only ask about the grinding for people who don't have the kta124 kit. Those toe arms seem to give more clearance over the stock ones. Only problem is I haven't installed them yet. Link to comment Share on other sites More sharing options...
islandborn Posted April 10, 2012 Share Posted April 10, 2012 Uh oh... I just order the same set up.... Will my issue be the same as on a '12 LGT? Would I need that kit too? Link to comment Share on other sites More sharing options...
cypher0117 Posted April 10, 2012 Author Share Posted April 10, 2012 Uh oh... I just order the same set up.... Will my issue be the same as on a '12 LGT? Would I need that kit too? I put my stock endlinks back on and the noise is gone. Might be getting the klc144 adjustable endlinks. Trying to decide if those are worth waiting 3 weeks for the $50 cheaper avo adjustable endlinks to get back in stock. You shouldn't need the kta124 kit. I got that because I bent one of my lateral links and threw my alignment out of spec Link to comment Share on other sites More sharing options...
