bmx045 Posted March 31, 2012 Share Posted March 31, 2012 So.... yah. I can get a nearly brand new aem cai from my friend for dirt cheap. It's a '11 wrx, so the maf hole is about 1-2mm smaller than the LGT maf(since 08+ wrx and sti use a smaller maf sensor inner diameter). The bolt holes line up, and the flush part is appropriate fitment however the inner maf glory hole is a c-hair too small causing my maf not to slide all the way in, anyone think I could miter it out to get my maf to slide down into it? Any other complications? Both sensor are identical in height, so clearance shouldn't be an issue. The mod seems straight forward, not sure if anyone has tried this yet... Link to comment Share on other sites More sharing options...
VermontGT Posted April 1, 2012 Share Posted April 1, 2012 God hates a coward. Link to comment Share on other sites More sharing options...
bmx045 Posted April 1, 2012 Author Share Posted April 1, 2012 sheeeeesh Link to comment Share on other sites More sharing options...
mwm5094 Posted April 1, 2012 Share Posted April 1, 2012 Use a dremel with a little sanding attachment. Should open it up easily. Link to comment Share on other sites More sharing options...
robitrice Posted April 1, 2012 Share Posted April 1, 2012 i have no idea but could u use a wrx MAF? but i like what he said^^ Link to comment Share on other sites More sharing options...
bmx045 Posted April 1, 2012 Author Share Posted April 1, 2012 Wire harness is different. Smaller connector Link to comment Share on other sites More sharing options...
Strizzy Posted April 1, 2012 Share Posted April 1, 2012 You could just buy my 73mm kstech intake for cheap and have no issues with install My bad luck build Link to comment Share on other sites More sharing options...
Nrw Posted April 1, 2012 Share Posted April 1, 2012 WAIT Mr.OEM intake brah is going aftermarket? Link to comment Share on other sites More sharing options...
bmx045 Posted April 1, 2012 Author Share Posted April 1, 2012 Ed's aem for $150! Link to comment Share on other sites More sharing options...
Strizzy Posted April 1, 2012 Share Posted April 1, 2012 That's more than what I'd be selling my kstech for. My bad luck build Link to comment Share on other sites More sharing options...
bmx045 Posted April 1, 2012 Author Share Posted April 1, 2012 modded it, fits perfect, used some rtv, scaled it no problem.... woosh. Link to comment Share on other sites More sharing options...
Nrw Posted April 1, 2012 Share Posted April 1, 2012 but all the noises now!! Link to comment Share on other sites More sharing options...
scoobydoobie Posted April 1, 2012 Share Posted April 1, 2012 AEM CAI is pretty quiet compared to the SRIs out there. Link to comment Share on other sites More sharing options...
