gr4v3r Posted March 25, 2012 Share Posted March 25, 2012 My clutch went out on my 05 LGT so its time i changed from the M to a SM flywheel. It seems I may not be able to being it to AZP Installs (shop of choice) so my question is, Will the OEM 06 wrx flywheel/clutch fit on my car without an issue or are other parts needed? When I told the mechanic I planned to do this he said "If you want me ordering non standard parts they better fit or your still paying for the labor and taking the parts." Unless someone has a flatbed in NY and wants to get me to AZP Link to comment Share on other sites More sharing options...
jfg22557 Posted March 25, 2012 Share Posted March 25, 2012 06 wrx SM flywheel + clutch will bolt up, and IIRC different flywheel bolts are recommended. Wait for someone more well versed to clarify, but no you wont have any issue with the oem 06 wrx clutch + flywheel. Triple A is indeed your friend , GL Link to comment Share on other sites More sharing options...
gr4v3r Posted March 25, 2012 Author Share Posted March 25, 2012 triple A got me into this mess lol. Towed me to a mechanic without me knowing that I can no longer be towed elsewhere. why do you mention triple a btw? Is there something they can be doing? Link to comment Share on other sites More sharing options...
frank_ster Posted March 25, 2012 Share Posted March 25, 2012 - push car down the street call aaa again Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
frank_ster Posted March 25, 2012 Share Posted March 25, 2012 or use my nifty tow bar ! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Max Capacity Posted March 25, 2012 Share Posted March 25, 2012 You must have the basic AAA towing, I paid for the 100 mile package. Yes the 06 WRX FW was the first replacement, or a 07-09 LGT FW it's also SM...seems it took Subaru a few years to realize they screwed up with the DM POS. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gr4v3r Posted March 25, 2012 Author Share Posted March 25, 2012 - push car down the street call aaa again I was going to do this but the shop the car is at is a certified AAA towing company. So they arent going to let me roll it out the tow it 5 feet away lol. Things suck right now Link to comment Share on other sites More sharing options...
Max Capacity Posted March 25, 2012 Share Posted March 25, 2012 This may help answer you FW questions. http://legacygt.com/forums/showthread.php/compilation-available-clutches-bp-bl-127691p5.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gr4v3r Posted March 25, 2012 Author Share Posted March 25, 2012 thanks, there is a lot of good info I found. I'm just scared the shady mechanic is going to say it doesnt fit then charge me for his time trying. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 25, 2012 Share Posted March 25, 2012 Also, you can have AAA tow the car to any shop you want. It's not their call. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gr4v3r Posted March 25, 2012 Author Share Posted March 25, 2012 yea the issue was i told them to tow it to the nearest shop. I didn't know i couldnt have it towed elsewhere after that. Link to comment Share on other sites More sharing options...
VermontGT Posted March 26, 2012 Share Posted March 26, 2012 The out-of-pocket cost of a tow is a shitty reason to have a shop - which you seem to feel apprehensive about - do any kind of work to your car, especially something like a clutch replacement. Do it the way you feel it should be done. At the end of the day it's your money; you should spend it the way (and the place where) you ultimately want to. Link to comment Share on other sites More sharing options...
gr4v3r Posted March 26, 2012 Author Share Posted March 26, 2012 The out-of-pocket cost of a tow is a shitty reason to have a shop - which you seem to feel apprehensive about - do any kind of work to your car, especially something like a clutch replacement. Do it the way you feel it should be done. At the end of the day it's your money; you should spend it the way (and the place where) you ultimately want to. I am pretty much with you on that, I think I'm going to have it towed to the shop I trust. We will see what they say tomorrow morning Link to comment Share on other sites More sharing options...
