Max Capacity Posted March 4, 2013 Share Posted March 4, 2013 IMO you need to let the engine sit cold for a long time. I normally check my oil after the engine has been off for hours, the longer the better. This gives the oil time to drain back into the oil pan. If you check it after the engine is just shut off, you may still have some oil up in the heads or other places. For the guy that measures his oil when he drains it, it's too late the damage is already done. You need to keep these engine full of oil. Never let it get low...or below full. Oil usage is not consistenant in these engines. Sometimes you can go 1500 miles and have no usage, the next week you can go 500 miles and be down some on oil level. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
iNVAR Posted March 4, 2013 Share Posted March 4, 2013 IMO you need to let the engine sit cold for a long time. I normally check my oil after the engine has been off for hours, the longer the better. This gives the oil time to drain back into the oil pan. If you check it after the engine is just shut off, you may still have some oil up in the heads or other places.Yeah, which would mean the dipstick would read low (if you checked without waiting so long), which means you'd end up "overfilling" per se.... which IMHO is better. I'd rather have there be a little extra oil in the pan than too little. In the end it probably doesn't matter. It really depends on how the dipstick is calibrated. Oil usage is not consistenant in these engines. Sometimes you can go 1500 miles and have no usage, the next week you can go 500 miles and be down some on oil level.HAH, ain't that the truth.... Link to comment Share on other sites More sharing options...
Max Capacity Posted March 4, 2013 Share Posted March 4, 2013 You've been here long enough, I'm should you know that I keep both mine a little over full rather than under full. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
iNVAR Posted March 4, 2013 Share Posted March 4, 2013 Then maybe you should change your name to "Over Max Capacity" Link to comment Share on other sites More sharing options...
Max Capacity Posted March 4, 2013 Share Posted March 4, 2013 Then maybe you should change your name to "Over Max Capacity" ROFL that's great... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
