Kipper Posted March 23, 2012 Share Posted March 23, 2012 I have a 96 subaru legacy L wagon. Automatic Tranny. My oil pan gastet is leaking. What is the easiest way to accomplish this? Do I have to take the exhaust off at the y-section? Any suggestions? Link to comment Share on other sites More sharing options...
monkeyposeur Posted March 25, 2012 Share Posted March 25, 2012 You just remove the mess of screws/bolts that hold it on, tap it off, scotch brite both mating surfaces clean, apply some RTV sealant like Permatex Ultra Gray (I go around each bolt hole too), screw it back on until the sealant starts to ooze it out and the bolts are finger tight, wait an hour and tighten the bolts to 3.7 ft lbs, and you're done. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted March 29, 2012 I Donated Share Posted March 29, 2012 Lift up the engine a bit and remove the exhaust. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Jippi Posted March 29, 2012 Share Posted March 29, 2012 i managed to wiggle it out with out messing with the exhaust. using a block of wood adn the floor jack i lifted the motor as high as it can go then i took some wood blocks i cut and shimmed the motor up at the mounts adn then wiggled the pan loose. it took a bit longer bit it was a holiday weekend and stores were close so exhaust partrs are hard to get if they break on the holidays \ Link to comment Share on other sites More sharing options...
