Dawkness Posted March 20, 2012 Share Posted March 20, 2012 I've noticed lately that shifting in my 5spd has gotten a lil notchy, clunky even. So I slid underneath the car to have a look and this is what I find. http://i36.photobucket.com/albums/e30/Street_Sleepa/921c3c59.jpghttp://i36.photobucket.com/albums/e30/Street_Sleepa/97c1e5c0.jpg Looks like fresh diff fluid where the shift linkage meets the tranny. It's a slow leak but noticeable enough when shifting and I'd like to tackle the issue ASAP. Problem is, I have no idea how it's leaking from that area. Anyone have any ideas? Thanks a ton in advance! Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 20, 2012 Share Posted March 20, 2012 Looks like the shifter fork rod seal is throwing fluid out. There are two ways to fix this: 1. Remove the tail shaft cover of your gearbox and replace the seal for the shifter fork rod 2. Keep your fluid topped off Link to comment Share on other sites More sharing options...
Dawkness Posted March 20, 2012 Author Share Posted March 20, 2012 Hmm, remove tail shaft cover from gearbox... why do I sense this will be a pita (hits the search button and crosses fingers) Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 20, 2012 Share Posted March 20, 2012 Hmm, remove tail shaft cover from gearbox... why do I sense this will be a pita (hits the search button and crosses fingers) Well you'll have to drop your drive shaft but it will save you from dropping the whole gearbox. I had to, to replace a $26 bearing that was walking Link to comment Share on other sites More sharing options...
