frank_ster Posted March 24, 2012 Share Posted March 24, 2012 U'r car hates u for taking it automatic car washes so it misfires. How many girlfriends u have. U Always change u'r avatar. he has no girlfriends jsut puctures from imgur/nsfw Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
No DRFT Posted March 24, 2012 Share Posted March 24, 2012 How many girlfriends u have. U Always change u'r avatar. 2. Both of his hands Repeat touchless car wash again? I have no control over drippie. Link to comment Share on other sites More sharing options...
bmx045 Posted March 25, 2012 Author Share Posted March 25, 2012 so i decided to perform a boost leak test. found out cyl 3 injector was leaking, i added an o-ring and the leak is gone. im sure water vapor would get sucked in through this leak when at idle in the carwash. we will see! Link to comment Share on other sites More sharing options...
frank_ster Posted March 25, 2012 Share Posted March 25, 2012 ^ no way Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
bmx045 Posted March 25, 2012 Author Share Posted March 25, 2012 Since it doesnt misfire any other time it probably wasnt a big enough leak to pull vapor in Link to comment Share on other sites More sharing options...
JermTheElf Posted March 25, 2012 Share Posted March 25, 2012 See if the problem persists when you spray inside of the car. That way you can localize the issue. Link to comment Share on other sites More sharing options...
bmx045 Posted March 25, 2012 Author Share Posted March 25, 2012 Jeremiah, i already did that. Read above Link to comment Share on other sites More sharing options...
JermTheElf Posted March 25, 2012 Share Posted March 25, 2012 Is your leather okay? Link to comment Share on other sites More sharing options...
skameigh Posted August 23, 2019 Share Posted August 23, 2019 Reviving an old old post.... I am having this issue now. When going through a touchless carwash with underbody wash, I will get misfires across all cylinders.... Any ideas? I've been thinking of replacing the coil packs just since they are original with 107k on them. Could it actually be steam causing the issue? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 23, 2019 Share Posted August 23, 2019 Reviving an old old post.... I am having this issue now. When going through a touchless carwash with underbody wash, I will get misfires across all cylinders.... Any ideas? I've been thinking of replacing the coil packs just since they are original with 107k on them. Could it actually be steam causing the issue? I sure hope you didn't get soapy water into the intercooler...sorry very old thread about car washes. Do you have a under engine cover on the car ? Your coils should be fine at that low mileage. I still have what came on the car, 278,000 miles later. Make sure the four connectors are tight on the coils. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
