.... Posted March 13, 2012 Share Posted March 13, 2012 Long story short: Installed VF48, which was clocked to work in the Legacy. Was not getting more than spring pressure boost, and attempted to install restrictor pill at tuner's request. The problem that I'm having is that the wastegate actuator and nipple on the turbo (which rotates) are now really close together. I can't get the lines back on without a 160 degree bend. I've attached a picture to show how the mechanic that did the install set it up before. Obviously it wasn't working that way, which is why I'm attempting to correct it. The only solution that I can come up with is to add a foot to one of the lines to make it a sweep instead of a bend. If I'm correct in my thinking, which I may not be, then adding that much distance to push the air will create massive lag. How do I correct this? If I had it to do over again I would have just gone with a turbo that was meant for the Legacy, but I took the advice of a mechanic that I trusted at the time and got the VF48. I'm hoping there is a way to get through this without swapping turbos. Link to comment Share on other sites More sharing options...
NavyMM06LGT Posted March 14, 2012 Share Posted March 14, 2012 On a small line like that, I wouldn't think that it would affect it that much as far as lag. I have a 3 port ebcs and have like 1.5 ft of line from the wg to the ebcs and the same for the compressor housing to the ebcs. Link to comment Share on other sites More sharing options...
.... Posted March 14, 2012 Author Share Posted March 14, 2012 Sounds like it's worth it to try it that way, then. Thanks. Link to comment Share on other sites More sharing options...
bmx045 Posted March 14, 2012 Share Posted March 14, 2012 your pill is in the wrong location. Link to comment Share on other sites More sharing options...
NavyMM06LGT Posted March 14, 2012 Share Posted March 14, 2012 Thats where he has it on the drawing.... his drawing is just weird... lol. I thought the same thing when i first looked at it. Link to comment Share on other sites More sharing options...
bmx045 Posted March 14, 2012 Share Posted March 14, 2012 there's a reason why subaru put the pill, with that hose length, for a reason. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2012 Share Posted March 14, 2012 Do what bmx045 say's, he has great avatars ! If you can put a smaller pill in there you will get more boost, but we need a tune for it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
NavyMM06LGT Posted March 14, 2012 Share Posted March 14, 2012 there's a reason why subaru put the pill, with that hose length, for a reason. So extend the like from the wg Link to comment Share on other sites More sharing options...
bmx045 Posted March 14, 2012 Share Posted March 14, 2012 I'm not sure what the confusion is, look at my picture, make your picture look like that with similar length hose. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2012 Share Posted March 14, 2012 I'm thinking you'll want to keep the compressor housing line with the pill in line with the waste gate, and the branch off the T to the solenoid. Can you run a 4-5" piece of hose with the pill, from the housing under that black braded hose and T to the WG ? Keep the pill close to the housing. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Nrw Posted March 14, 2012 Share Posted March 14, 2012 I'm not sure what the confusion is, look at my picture, make your picture look like that with similar length hose. Well I know every time I look at your post I get distracted. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2012 Share Posted March 14, 2012 well i know every time i look at your post i get distracted. ditto !!!! 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
.... Posted March 14, 2012 Author Share Posted March 14, 2012 To clear up some confusion going on in here... The drawing I made is where the mechanic put the pill when he installed the turbo. The wg and the turbo were not inline, and I was not getting proper boost. That's what I'm trying to correct. I can't just do what is in the picture that bmx045 posted because the nipple on the wg actuator and the one on the turbo are too close together, they would overlap each other by a half an inch if I rotated the one side around. If I try to force it, I get a major kink in the hose, no air could possibly flow. What I'm going to try this afternoon is to extend the line on the turbo side of the t fitting so that it is a smooth curve instead of a major bend. Link to comment Share on other sites More sharing options...
.... Posted March 14, 2012 Author Share Posted March 14, 2012 I'm thinking you'll want to keep the compressor housing line with the pill in line with the waste gate, and the branch off the T to the solenoid. Can you run a 4-5" piece of hose with the pill, from the housing under that black braded hose and T to the WG ? Keep the pill close to the housing. I think I see what you're getting at. I'll give that a shot. Link to comment Share on other sites More sharing options...
