Toallhisdoom Posted March 13, 2012 Share Posted March 13, 2012 98 legacy gt limited sedan. ej25 So part of my exhaust broke the other day so going to be re doing it. I cant remember but the last time i was under there i believe i only saw a pre cat o2 sensor. So from my experience this means i can remove the cat without throwing a CEL? Anyone know if there is a post cat sensor i missed? Also if i get the 2.5 rs raceland coil overs, is there anything else i need to install? Will the drop from installing these cause any allignment issues that i will need to buy another kit for? Thanks guy! Link to comment Share on other sites More sharing options...
subikid90 Posted March 13, 2012 Share Posted March 13, 2012 Yes there is a post cat O2 sensor. You can use a spark plug fouler to space the O2 sensor out tho. You will most likely need camber bolts for the coilovers. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Toallhisdoom Posted March 13, 2012 Author Share Posted March 13, 2012 What camber bolts should i get? Do they make them specifically for our cars? I know the coilovers are for like 02 2.5rs or some shat. Link to comment Share on other sites More sharing options...
.blackgt. Posted March 13, 2012 Share Posted March 13, 2012 Subikid90, can you explain how to bypass the 02 sensor with a spark plug fouler? Pm me if you'd like. Link to comment Share on other sites More sharing options...
bmx045 Posted March 13, 2012 Share Posted March 13, 2012 Subikid90, can you explain how to bypass the 02 sensor with a spark plug fouler? Pm me if you'd like. you're barking up the wrong tree. what are you trying to do, i can bet you a fouler is not the right answer Link to comment Share on other sites More sharing options...
Toallhisdoom Posted March 13, 2012 Author Share Posted March 13, 2012 http://www.sl-i.net/FORUM/viewtopic.php?f=39&t=14675&hilit=02+cat Link to comment Share on other sites More sharing options...
.blackgt. Posted March 13, 2012 Share Posted March 13, 2012 I have never heard of a fouler doing the job, just the resistor mod for the up in our 05+ models. pm coming your way bmx Link to comment Share on other sites More sharing options...
.blackgt. Posted March 13, 2012 Share Posted March 13, 2012 Just for reference, its called a "spark plug non-fouler." Still not sure about it, but will be looking into it more. Thanks for the link. Link to comment Share on other sites More sharing options...
subikid90 Posted March 13, 2012 Share Posted March 13, 2012 Yes it is a spark plug non-fouler lol I have used them before and passed emissions. Sometimes you might have to use 2 of them it all depends on the car. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted March 14, 2012 I Donated Share Posted March 14, 2012 Every OBDII car (96 and newer) has an o2 sensor before the cats and after. Every one - no exceptions. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
