Searcher451 Posted March 9, 2012 Share Posted March 9, 2012 The monitor on my 2008 Legacy went on the fritz and required a replacement. When the new monitor was installed this past week, it lost the ability to retain the outside temperature on the map screen (upper right), as was previously the case. It just disappeared, and I can't figure out how to get it back again ... even after reading the manual. Any suggestions? Thanks in advance if you can provide some help. I'm running the updated software, by the way: version 6.1 (I thik that's the latest). Link to comment Share on other sites More sharing options...
car_cursed Posted March 10, 2012 Share Posted March 10, 2012 If it helps, I never had outside temp on my map screen just the info screens. Link to comment Share on other sites More sharing options...
Strizzy Posted March 10, 2012 Share Posted March 10, 2012 Go to your info screen. Then tap 'SET.' Tap 'OFF' under 'OUT TEMP' so it says 'MAP.' Done. My bad luck build Link to comment Share on other sites More sharing options...
