Baddog Posted March 9, 2012 Share Posted March 9, 2012 Hey there, Hate to put in a link here but it pretty much explains my issue and what I have fixed in order to resolve this. I have been chasing this problem for a LONG time now. http://www.sl-i.net/FORUM/viewtopic.php?f=12&t=22165 I have replaced: Brakes (Calipers, rotors, pads) Axles Steering Rack Inner and Outer tie rod ends Transmission and Engine mounts are new and torqued properly and are not ripped or torn. Rims and tires are new (did it on my old set) and are balanced and have been balanced numerous times by different shops which have all checked out. Wheel bearings I have taken the car to a couple shops with NO luck in them finding anything. Link to comment Share on other sites More sharing options...
nick.cfrancis Posted March 9, 2012 Share Posted March 9, 2012 Did you try replacing the caliper bracket (with the slides)? Link to comment Share on other sites More sharing options...
Baddog Posted March 9, 2012 Author Share Posted March 9, 2012 Yes new slider pins Link to comment Share on other sites More sharing options...
jamesm113 Posted March 9, 2012 Share Posted March 9, 2012 ball joints? Link to comment Share on other sites More sharing options...
98LGTLover Posted March 9, 2012 Share Posted March 9, 2012 My Jetta had this issue really bad and I ended up needing control arm bushings... Don't know if that would be anything similar to what your Scoob needs. Link to comment Share on other sites More sharing options...
Baddog Posted March 9, 2012 Author Share Posted March 9, 2012 Ordering the whiteline bump steer kit (includes ball joints) and new front control arm bushings. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted March 10, 2012 Share Posted March 10, 2012 Have you replaced any of the bushings so far? Link to comment Share on other sites More sharing options...
Baddog Posted March 10, 2012 Author Share Posted March 10, 2012 Steering rack bushings with whitelines. Link to comment Share on other sites More sharing options...
