OgDiesel89 Posted March 4, 2012 Share Posted March 4, 2012 never really payed any attention to it cus i never really drive fast, always cruising at speed limit. but when WOT, i get this weird smell its not gas,oil or anti freeze those scents i recognize more like sulfur or something rotten. can't really explain it. any body have same issue, or any idea what it could be? goes away as soon as i slow down. any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
jasejase Posted March 4, 2012 Share Posted March 4, 2012 clutch?? Little exhaust build up? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 4, 2012 Moderators Share Posted March 4, 2012 that would be the smell of car farts. Put a bottle of "Beano" in and it'll go away. Kidding. But seriously, I call them car farts...my wife's CR-V has the smell every now and then too. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
OgDiesel89 Posted March 4, 2012 Author Share Posted March 4, 2012 clutch?? Little exhaust build up? nope not clutch, i consider myself a good driver. lol & it doesn't smell like exhaust fumes either.. that would be the smell of car farts. Put a bottle of "Beano" in and it'll go away. Kidding. But seriously, I call them car farts...my wife's CR-V has the smell every now and then too. Is it normal that it does it every time i WOT? doesn't matter what gear as long as i WOT it'll smell soon after.j doesn't really bother me & car seems to be running good, i just want to make sure so i can address the problem before something (else) goes wrong. Link to comment Share on other sites More sharing options...
mwm5094 Posted March 4, 2012 Share Posted March 4, 2012 Are you catless? Link to comment Share on other sites More sharing options...
jasejase Posted March 4, 2012 Share Posted March 4, 2012 the rotten egg smell certainly sounds like an exhaust / cat related issue. Possibly stemming from something as, as the case with most cat issues. There is a small amnt of sulfur traces in gasoline... When the car is either running rich, or has a failing, overworker, or bad cat converter, you can get that smell (unused fuel burning essentially). Typically a bad cat converter is a sign of something else wrong (fuel injection, o2 sensor, etc) in the car, as cats are meant to last. if its infrequent, its likely just a hiccup and i wouldnt worry about it. Any current mods? Link to comment Share on other sites More sharing options...
robinlsb Posted March 4, 2012 Share Posted March 4, 2012 never really payed any attention to it cus i never really drive fast, always cruising at speed limit. but when WOT, i get this weird smell its not gas,oil or anti freeze those scents i recognize more like sulfur or something rotten. can't really explain it. any body have same issue, or any idea what it could be? goes away as soon as i slow down. any help would be greatly appreciated. Well, other than check for oil/coolant leaks, what happens is at maximum HP you are puting a lot of heat out of the motor. You end up cooking any oil or crap from the road, and the smell will get into the vents. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
vtbimmer Posted March 4, 2012 Share Posted March 4, 2012 Smell @ WOT is the smell of victory.... Link to comment Share on other sites More sharing options...
robitrice Posted March 4, 2012 Share Posted March 4, 2012 its probably something related to a cat.... Link to comment Share on other sites More sharing options...
OgDiesel89 Posted March 5, 2012 Author Share Posted March 5, 2012 Are you catless? nope, cat still there, i think lol just got the car about a month ago the rotten egg smell certainly sounds like an exhaust / cat related issue. Possibly stemming from something as, as the case with most cat issues. There is a small amnt of sulfur traces in gasoline... When the car is either running rich, or has a failing, overworker, or bad cat converter, you can get that smell (unused fuel burning essentially). Typically a bad cat converter is a sign of something else wrong (fuel injection, o2 sensor, etc) in the car, as cats are meant to last. if its infrequent, its likely just a hiccup and i wouldnt worry about it. Any current mods? as for mods, nothing big Megan Coilover Damper kit & magna flow exhaust. smell is persistant tho, every time doesn't fail. o2 sensor would throw a code right? as of right now i have no CEL. Link to comment Share on other sites More sharing options...
OgDiesel89 Posted March 7, 2012 Author Share Posted March 7, 2012 update. i am catless 0_o had to take a look. Link to comment Share on other sites More sharing options...
Hanger Posted March 8, 2012 Share Posted March 8, 2012 My car has been emitting this "burned rubber" smell coming in from the air vents and even when i shut off the car i smell it around the car. ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
Drift Motion Posted March 8, 2012 Share Posted March 8, 2012 ^ plastic bag under the car/stuck on exhaust? Link to comment Share on other sites More sharing options...
Hanger Posted March 8, 2012 Share Posted March 8, 2012 my car is too low can't see under it!!! AHHHHH ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
