Joaks Posted March 3, 2012 Share Posted March 3, 2012 I have a remanned 97 EJ 22 that will idle fast but only some of the time and only in warm weather. Restarting the car will usually fix it. Any ideas for the cause? I have only about 12k on the engine so I wouldn't expect things to stick (throttle body?) Yet. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted March 3, 2012 I Donated Share Posted March 3, 2012 Clean your mass air flow sensor, idle air control valve, and egr valve (if equipped) -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Mykids97outbackwgn Posted March 3, 2012 Share Posted March 3, 2012 thats def. your IAC is clogged up I would remove it and clean it, it should fix the problem....a new one is expensive Link to comment Share on other sites More sharing options...
Joaks Posted March 4, 2012 Author Share Posted March 4, 2012 thats def. your IAC is clogged up I would remove it and clean it, it should fix the problem....a new one is expensive Why are you sure it is the IAC? That was going to be the last of the three I would check because it seems to be the hardest to removed/replace? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted March 4, 2012 I Donated Share Posted March 4, 2012 Experience -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Joaks Posted March 4, 2012 Author Share Posted March 4, 2012 Experience Not you, Brok. We know you have "the gift." I was asking the other guy why he selected the one of the three choices because I hoped it was going to be a dirty MAF which I could clean and install in 10 min. Link to comment Share on other sites More sharing options...
