luvmylegacy98 Posted February 23, 2012 Share Posted February 23, 2012 the car is a 1998 legacy gt. it recently started making this noise when i make a right turn. Link to comment Share on other sites More sharing options...
travgag Posted February 24, 2012 Share Posted February 24, 2012 sounds like your strut or strut bearing possibly ? jack up the car maybe and look, and does it do it in place, while not moving ? Link to comment Share on other sites More sharing options...
Joaks Posted February 25, 2012 Share Posted February 25, 2012 Rack and pinion? Is there a steep crown on that road you were on? Looks like the steering wheel is turned when you are going straight. Does it make noise on bumps? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted February 26, 2012 I Donated Share Posted February 26, 2012 Sounds like a bad CV axle to me. You DESPERATELY need an alignment. And your check engine light is on -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
luvmylegacy98 Posted February 27, 2012 Author Share Posted February 27, 2012 i have an appointment for an alignment Thursday this week, the check engine light is the p0480 code which is a bad cooling fan relay, but both fans work just fine and the car doesn't over heat at all. it does not make any noise when im not moving. almost no noise at all when turning left and occasionally i hear it when driving straight. it gets louder as i get on the gas more and more. i've recently replaced the cv axle on the passenger side. also the car has taken to ripping the boots on the rack and pinion up so there is a good chance that has something to do with it cause dirt and what not can get in. seems like everytime i fix one thing on this car something else goes wrong within the week Link to comment Share on other sites More sharing options...
luvmylegacy98 Posted February 27, 2012 Author Share Posted February 27, 2012 now that i think about it, the cv axle does make sense. cause the outside joint on it has to swivel so that the wheel can turn. last time i had the car apart it didnt look like the boot was ripped or anything so i dont think anything got in there. but i'd like to be sure before i go out and buy a part i replaced less than 3k miles ago. if it is something to do with the rack and pinion and i go buy a 80 dollar part that doesnt fix it im gonna be upset. i have a parts car that has the entire steering rack and everything. i know it would be cheaper, but would it be easier to replace the whole steering rack? but im not going to do that its the cv joint. and i though it might be something with the strut but i wasn't aware that the strut has its own bearing Link to comment Share on other sites More sharing options...
JJay03 Posted February 28, 2012 Share Posted February 28, 2012 Sounds like the axle to me also. Link to comment Share on other sites More sharing options...
